Help with a CPU cooler please.
Last response: in CPUs
deadly_accurate said:
arctic freezer i30 have a good review and expert recommendation.cheaper too.30pound i think.it can easily handle overclocked 2500k 4.5Ghz.
Are you sure that would be a good cooler for me? i play games ALOT and at this moment my cpu's idle temp is between 48 and 51C on 4 cores for some reason when it should be below 40... ive found a few more but i dont know if they will do what i need what do you think?
http://www.overclockers.co.uk/showproduct.php?prodid=HS...
Ive found another 2 zalman coolers that look good and have good reviews aswell
http://www.ebuyer.com/268496-zalman-cnps9900-max-blue-i...
At the very most if i absolutely have to i could buy this, But its bit over my budget
http://www.ebuyer.com/277523-corsair-hydro-series-h100-...
Related ressources
dark pro is quite good too,but i wouldnt spend more than 30 quid on cpu cooler alone.if money isnt a problem,go for h100,if budget do concerns, i30 freezer would do almost the same job as those monstrosities.
Ok thank you :)  but what is better between the Cooler Master Hyper 212 Evo and the i30 freezer? and would there be a big diffirence between them and the h100?
I have an X6 3.8ghz 192w tdp overclocked AMD with a 212 evo and by golly, I lost 50 degC by stepping up from the stock cooler.
My CPU temp under stress is 63degC under prime95!
Ask the community
