Hp slimline s5-1020 power supply specifications
  • Power Supplies
  • Hewlett Packard
  • Components
Last response: in Components
July 2, 2012 10:09:23 PM
Hello,
I need a new psu for Slimline s5-1020, which one fits and works the best? Thanks.
More about : slimline 1020 power supply specifications
July 17, 2012 8:54:11 PM
The ATX ones works with the PSU. You select the volatge power.
Good Luck!
m
l
July 17, 2012 9:25:22 PM
Good Luck!
whoa holdup there, the PSU for a Slimline s5-1020 is NOT regular ATX. Most PSUs for smaller PCs are proprietary I believe, so it will be difficult to find a match for you PSU. I'll be straight up honest on I how i would go about this. First, measure your current PSU's physical dimensions. Next, go straight to Newegg.com and look at small form factor PSUs (SFX, TFX, uATX, mini-itx, etc.) and compare their dimensions with the one you have. If they're the same or really close, go ahead and get it. You won't have as many choices, and you're less likely to find a quality one, but there it is.
m
l
