Which power supply for this build?
Here is my build.
Intel Pentium E2160 Allendale 1.8GHz LGA 775 65W Dual-Core Processor BX80557E2160
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116036
ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX All Solid Capacitor Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
ADATA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model AD2U800B1G5-DRH
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
XFX PVT84JUDD3 GeForce 8600GT XXX 256MB 128-bit GDDR3 PCI Express x16 SLI Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150229
I am wondering what cheap budget power supply would be good for this build? This is a reminder that this build is old and I haven't taken the time to fix it due to certain circumstances, but now i finally decided to fix it.
9 answers Last reply
More about which power supply build
  1. 400-500 watts is plenty. I recommend one of these brands: antec, ocz, corsair, seasonic, or enermax. All are tested properly and rated correctly for max loads. Newegg has this deal: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026. The 500w version is $40 after rebate.
  2. Yes a good 430w version will work fine:
    here is a good one
    CORSAIR Builder Series CX430 V2 (CMPSU-430CXV2) 430W ATX12V $49
  3. cool but does that power supply has everything that my motherboad and cpu need? like the plugs and stuff
  4. I dont think this one will work, since i have a 4 pin only, for my cpu
  5. Those newer power supplies have 8 pin connectors for newer boards, but they split up into two sections so you can use one for your 4 pin board. It will work fine. The 4 pin only fits one way; simply line up the clip side to the clip side on the board; it will slide in easy when lined up correctly. Some ps have both the 8 pin and 4 pin. Here's another ps: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371046
  6. Im really thinking bout getting the corsair cx430, my quesion is can that powersupply handle a little bit of overclocking?
  7. Yes, if you don't get greedy; if your default cpu fsb in the bios is 200, try 240 or 250 for the fsb setting.
  8. yes it will serve you well; good gaming
Power Supplies Build Components Product
