Solved
Is my power supply good for this build?
I will be using it for gaming and websurfing.
Is this PSU suitable for my setup?
On an unrelated subject, if you have any recommendations please tell me.(so long as it doesnt raise the price)
CPU: Intel Core i5-2320 3.0GHz Quad-Core Processor ($189.00 @ Covetech)
Motherboard: ASRock H77 Pro4/MVP ATX LGA1155 Motherboard ($99.00 @ PCCaseGear)
Memory: GeIL Enhance CORSA 8GB (2 x 4GB) DDR3-1600 Memory ($52.00 @ Mwave Australia)
Video Card: Asus GeForce GTX 560 Ti 1GB Video Card ($229.00 @ Mwave Australia)
Case: Cooler Master Elite 430 ATX Mid Tower Case ($49.00 @ PCCaseGear)
Power Supply: Antec 620W ATX12V / EPS12V Power Supply ($115.00 @ Mwave Australia)
Operating System: Microsoft Windows 7 Home Premium SP1 3-Pack (64-bit) ($99.00 @ Scorptec)
Total: $832.00
5 answers Last reply Best Answer
More about power supply good build
  1. Is that the Antec High Current Gamer 620W? yes, it's a great power supply. However, you can run the 560ti off of a 500W power supply which will save you money to upgrade to a Z77 motherboard.
  2. Is a Z77 worth it? I origiginally had a Z77 but i swapped out for a better GPU
  3. Best answer
    Z77 is worth it! It features a bit more support for things that will be very useful in the future:
  4. I changed the board to Z77 for an extra $20. I went for an asrock pro 3 motherboard. Does this sound like a good option to you?
  5. Best answer selected by Panzer4.
Power Supplies Components Product
