I'm getting my new pc parts 2morrow morning to build my very first pc and amoung the parts I also ordered a anti static wrist band at first was just because i was being a worry wart Because its my first pc build and all but now since I ordered it the weather at my place has gotten so cold I cant sleep with out sleeping nxt to the heater
and so I've been reading up on what causes static and one of them is very cold weather and instant heat mixed like if u wear a jumper in the cold.
while trying to get the house warm changing the cold to hot instantly inside the house and that creates static
so I need to wear the static wrist band but problem is idk what to clip the anchor clip to because the case is limited edition and is painted all in black the original comes with normal unpainted Chassis and I dnt feel safe clipping the anchor clip to the earth inside of the outlet I'm Australian if that helps on the power outlet we have n how it works so with them 2 options outta the question what to clip to so I dnt static damage my $1056 build btw the case is called a aero cool VXE limited edition case
