Solved
Advices me about Power supply
  • Power Supplies
  • Components
Last response: in Components
July 4, 2012 5:05:31 AM
Hello Friends :hello:  :hello:
I have intel dual core E5700 3.00 Ghz processer
simmtronics G31e motherboard
Simmtronics DDR2 800Mhz 4 gb Ram
hitachi 500gb hard disk
Lg dvd writer
His Radeon HD 6770 1GB DDR5 Graphic card
please tell me which Power supply is best for my system
I think Corsair GS600 is perfect for my system
i live in india and my budget is Rs.4,500 :bounce:
More about : advices power supply
a b ) Power supply
July 4, 2012 6:06:00 AM
that would work well, but a 450/500W supply work well also, if you can get one that much cheaper to make a difference
m
l
a b ) Power supply
July 4, 2012 7:02:46 AM
Corsair CX430
Antec VP450
Corsair GS500
Corsair CX500V2
Corsair CX600V2
SeaSonic S12II 520W
All these PSUs would be (more than)sufficient for your rig & would fit in your budget as well.
m
l
July 4, 2012 7:49:17 AM
Bro coarsair Gs 500 Is in Rs.4350 on flipkart an corsair GS600 is RS. 4408 i think Corsair GS600 is better for me
m
l
Best solution
a b ) Power supply
July 4, 2012 7:59:19 AM
Actually, the GS500 is usually around 4k. But still, since the GS 600 is in your budget & is more than sufficient for you rig, go for it. :)
a c 243 ) Power supply
July 4, 2012 11:33:51 AM
You have asked this 10 or 12 times here
You registered and asked at jonnyGuru
How much advice do you need before you make a decision ?
m
l
July 12, 2012 7:40:01 AM
Best answer selected by Randeepx9.
m
l
