Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > AMD Radeon > 6950 crysis and skyrim major stuter! (ready to pay is issue is solved)
Forum Graphics & Displays : AMD Radeon 6950 crysis and skyrim major stuter! (ready to pay is issue is solved)
Here is my build:
Amd 1090t 3.2 ghz @ 3.5v (The stock voltage was 4.5v!)
1tb samsung @ 7200 RPM
8gb kingston ram @1333 mhz?
Hd 6950 asus graphics card
Air cooling thermal take silver arrow 2
When I play a game for example skyrim, or crysis and I look around with the camera or go into a new area the game jitters! bad! Once I have looked around my frame rate is like up to 60fps on crysis max settings or even skyrim max settings and the jitter stops (yes I have tried both games on the lowest settings but same problem presists.)
I need major help in this issue I'm ready to pay if someone can help me through skype or even on here aslong as my issue is solved!
Reply to supmag
First off, I assume that is a typo, but if not, you are killing your CPU if you are able to run it at that high a voltage, max is 1.475.
Both of those games stream textures from the HDD, so that is likely where you should start focusing.
When was the last time you did a defragmentation of the HDD?
Are all (chipset) drivers up to date and correctly installed?
Seeing as it is an ASUS graphics card you have, did you by chance install and use the GamerOSD? If yes, try and uninstall that, it is known to cause stuttering when panning the camera.
Message edited by LothDK on 01-15-2012 at 11:53:31 AM
Reply to LothDK
- 0 +
the gamer osd is installed but I never use it and yes that was a typo Im actually running the processor at 1.35.
all the drivers seem to be up to date and Ill try uninstalling the gamer osd
Thank you very much for the reply! I will actually pay if this issue is resolved :D
Reply to supmag
- 0 +
Just tested it, no difference :/
Reply to supmag
- 0 +
Pay to who? In this forum the help is free! :hello:
Could you download HWmonitor and check the temperatures when the jittering starts?
Message edited by Sunius on 01-15-2012 at 04:42:54 PM
Reply to Sunius
Do you have the 1GB or 2GB HD 6950?
Reply to Warmacblu
- 0 +
It doesn't make any difference. Even 1GB one should have 60 fps @ high.
Reply to Sunius
- -1 +
I wholeheartedly disagree with you. If he is trying to run the game at max settings with 8x AA then he may be running out of VRAM, especially if he has high resolution texture packages installed. Skyrim uses 1.2-1.5 GB of VRAM on my system and I am not using any high resolution texture packages, just running with Ultra settings.
Reply to Warmacblu
- 0 +
tell you this now skyrim will only run at 60fps max, i have 3 x 6970 2gb cards and i only hit 60fps and never been under or over it but still max is 60fps. its a game issue so dont stress on that side.
as for your problems what drivers are you using and each time you instal them do you install the AMD profile aswell ?
also DONT install ati tray tool or msi afterburn or anything else of that nature they will do naughty things during game play. last of all what anti virus do you have installed ?
------------------------------ Asus Rampage 4 Extreme, Intel 3930K 4.8Ghz, 32GB Gskill Ripjaw Z 2133Mhz, 2x OCZ Agility Vertex 3 240GB SSD in Raid O, 3 x Asus DC2 TOP 3 GB cards 1000/1400 in Crossfire X, 5 x Samsung Syncmaster 24" for Eyefinity with no Bezel's
Reply to Spoony
turn off motion blur. and agree, i had troubles playing above 1024x768 until I got a card with more than 1gig of ram. other than that you have stuff running in the back ground and it shouldn't be. turn off all apps/auto updates-instant messaging-malware apps.
Reply to swifty_morgan
Latest AMD drivers use them (http://support.amd.com/us/kbarticles/Pages/Catalyst121apreviewdriver.aspx). They address many Skyrim issues as well as others.
Reply to DogSnake
gotta add, the architecture of the cards are different now... 6960... I would look for external forces more than anything. did you try reinstalling the drivers and did you patch the game ?
Again, when is the last time you cleaned up and defragged your hd?
What power supply are you using?
------------------------------ Core i3-2100/Asrock H61/8GB1333/XFX HD5850oc/WD Black 500/Antec 300/Antec EA380w bronze
Currently playing Deus Ex:HR a second time on Hardcore
Reply to geekapproved
Are you sure you don't have v-sync turned on in CCC? Because having Skyrim run only at 60fps for that system is ridiculous and 60 is what most monitors I know of refresh at.
Reply to nicholasmg77
- 0 +
its a game bug that needs to be addressed just like it ONLY using 2gb of ram max which is stupid.
its a design flaw
Reply to Spoony
its a design flaw
I thought it was 1GB and I believe they patched it so now 4GB can be used.
Reply to Warmacblu
- 0 +
i wish it was my system STILL wont do more than 2 and STILL only does it with 1 card and the eyefinity patch sucks balls aswell menu's are big as hell and just insane, so i use widescreen gaming forums patch to adjust it and also im now running HD modes and other stuff for improved graphics makes a big difference but still not right and is doing my nut in for such an EPIC game :(
i hear a patch is int he works but its still in progress for me its not coming sooner,
Reply to Spoony
- 0 +
I am maxing skyrim out with GTX 560 Ti 1GB @ 1080p. He said he it didn't work with lowest setting. VRAM IS NOT THE ISSUE HERE!
Reply to Sunius
- 0 +
i wasnt saying it was the VRAM as the issue, nobody did was was stating past issues with the game that are no resolved and STILL max problems for gamers today unless worked around.
the issues for me would be that its a problem with the drivers most of all or settings are too high for hardware
Reply to Spoony
I missed the part where he said he tried the game on the lowest settings and still had the issue, my apologizes.
OP - what are your temps at during the stuttering? I think drivers may be an issue here but I have little to no experience with AMD drivers so take the advice of the others when it comes to the proper drivers.
Reply to Warmacblu
this is pretty much normal for any game to jitter a bit when loading new data. You look around, data gets loaded, and once it's loaded the jittering goes away. It's normal. An SSD will speed things up, but there isnt really anything else you can do.
------------------------------ INTEL CORE 2 Q6600 @ 3.49GHz, CM Hyper TX3, ASUS P5N-D, 8GB DDR800 RAM, Powercolour HD6850, 650w Antec Trupower New PSU
Reply to iam2thecrowe
- 0 +
Hey everyone! ok its gone! it seems like the drivers I installed of the cd had a bug so I uninstalled my device and reinstalled it and now I have some old drivers but the jitter is gone! now one problem remains I am getting low fps at high settings where as I used to have a really good frame rate but it stuttered quite allot! I mean a hell of allot!
and is 60fps not good? but it looks sooooooo smooooooth I have an acer 23 inch monitor full hd with response of like 5 ms and I have an asus radeon 6950...
Reply to supmag
- 0 +
its a 1gb card also is it worth flashing mine to a 6970 equvalant?
and thank you soooooooooooo much for every ones replies really appreciate it :D
Reply to supmag
- 0 +
it wont flash to a 6970 as there is NO version of bios to support it due to being only 1GB as ALL 6970 cards or 2GB.
sorry buddy.
only advice on that score is get another card for crossfire if a driver update doesnt work
Reply to Spoony
- 0 +
are you 100% on that? that's sad :(
Reply to supmag
- 0 +
Also for everyones information yes I defraged the hdd also I have a 500w crosair power supply and still getting these shitty 30 fps on max settings :(
Reply to supmag
- 0 +
Oh and everytime I try installing drivers it says INF file not found? wtf is this
Reply to supmag
- 0 +
turn AA down and fps will go up lol
Reply to diec4st
- 0 +
¬¬ crysis doesn't have that option :/
Reply to supmag
- 0 +
It's Post Processing @ crysis 2. Try extreme instead of ultra for that setting.
Reply to Sunius
- 0 +
How can I find out what fps I#m getting? right now im just making guesses...also does it mater if I get more than 60 fps cause my monitor is 60hz.....
Reply to supmag
- 0 +
It doesn't matter. You can download fraps and when you have it on while gaming, it will say how much fps you at the upper left corner.
Reply to Sunius
There are 1465 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 3 hours ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
