Sign-in / Sign-up
Solved
Need help purchasing parts
  • New Build
  • Systems
  • Product
Last response: in Systems
March 21, 2012 3:10:48 AM
Hello everyone my friend got a EVGA x58 FTW3 last year and he just got his tax return so he wants to get parts for his computer. he already has a LGA 1366 i7-930 intel 2.8. all he wants is a:
Hard Drive
Blurayburner
Memory
Video Card $400
PSU
all that for at least less than $900. please link me from tigerdirect if you can. newegg is fine too. thanks for all your help. :)
More about : purchasing parts
Best solution
March 21, 2012 3:34:10 AM
Video card is a no-brainer: http://www.newegg.com/Product/Product.aspx?Item=N82E168... - Sapphire Radeon HD 7870
BD-R burner: http://www.newegg.com/Product/Product.aspx?Item=N82E168... - LG BD-R Burner
HD: http://www.newegg.com/Product/Product.aspx?Item=N82E168... - Seagate 1TB
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E168... - Seasonic X750 Gold
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E168... - Kingston Hyper X
Total: $785 - you can use the difference to get either a nice SSD or a good cooling solution.
March 21, 2012 10:43:45 PM
The 570 is a good choice, but now the 7870 easily eclipses it: http://www.tomshardware.com/reviews/radeon-hd-7870-revi...
OCZ PSUs are very questionable reliability at best, and I do not recommend getting the Vengeance RAM with the tall heat sinks as that will interfere with any aftermarket heat sinks you plan on using.
Try these:
PSU: http://www.tigerdirect.com/applications/SearchTools/ite... - Corsair TX750
RAM: http://www.tigerdirect.com/applications/SearchTools/ite... - Crucial Ballistix Sport 8GB
Video Card: http://www.newegg.com/Product/Product.aspx?Item=N82E168... - Sapphire Radeon 7870
m
l
March 22, 2012 3:07:56 AM
Whats the best video card out there right now?
m
l
April 3, 2012 4:46:12 AM
Best answer selected by Mbernardo.
m
l
