Solved
Can I buy a separate audio input & insert it/plug it in to my laptop?
  • Laptops
  • Audio
  • Sony Vaio
  • Components
Last response: in Components
July 4, 2012 11:23:08 PM
I'm not sure if this exists...
My VPCSB11FX Sony Vaio does not have an audio input. Outrageous, right?
Anyway, I was wondering if there is such a thing as an audio input that can be connect to your audio output, or the plugs in to a USB port.
Maybe what I'm saying is insane, but it turns out the computer's built-in mic is crap, so I want to use my Beats by Dre as a mic, but there's no input!
If this is outrageous, then please tell me there is a microphone that can be plugged into a USB port, and give me a good model.
Thank you for your help!
More about : buy separate audio input insert plug laptop
Best solution
a c 249 D Laptop
July 4, 2012 11:34:56 PM
Hi :)
Of course its got an audio input...use the microphone socket....but yes there are USB souncards (like a little usb stick with mike and headphone sockets on them)
All the best Brett :)
July 5, 2012 1:33:50 AM
Brett928S2 said:
Hi :)
its got no mic socket... but awesome, do you know how much they cost?
m
l
July 22, 2012 2:15:28 PM
Best answer selected by hoorayforfood.
m
l
