Hello,
I have just installed windows pro 64 bit on a computer i just built from scratch. the windows install worked fine, all mobo and other drivers are installed and working correctly.
I have a 64gb SSD boot drive where windows is installed and working.
I went into computer management to initialize and format my HDD, but I am getting an error. I initialized the disk like normal, and went oformat using NTFS, and it took a long time but in the end it did not format. the disk shows up in comp mgmnt, but shows not initialized with a little red arrow pointing down next to it. I tried to reformat again, and virtual disk manager had a pop up error that says "The semaphore timeout period has expired."
Google shows it as a network issue where you are trying to transfer large files, but I am not transferring anything, just formatting a hard drive... does the bare drive tag have something to do with it?
My HDD:
Western Digital Caviar Blue WD5000AAKS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
My HDD:
