Long time reader, first time posting.
Approximate Purchase Date: May 1st (enough time to build it for the release of Diablo 3)
Budget Range: $2,500.00 USD, but complicated
System Usage: Diablo 3, Skyrim, Dragon Age 2
Preferred Website for Parts: Newegg
Country: USA
Overclocking: Yes (nothing crazy)
SLI or Crossfire: Yes (in the future)
Monitor Resolution: 1920x1080 (3 displays in the future)
I have built one system previously, an old core2duo with an 8600 gts video card. Yes this system was built a long time ago. I have been waiting a long time to build a new system (1.5 years). I kept waiting for the next game I wanted to play to come out to justify spending money and I guess Diablo 3 is it. This game is not taxing by any means, however I want a system that can play any game I throw at it at maximum settings on a 3 monitor 1920x1080 setup. I received a promotion and now have the money and desire to build the new system. The stars seemed to align with both ivy bridge and new graphics cards coming out in april but I now am slightly doubting myself with nvidia not releasing GK110 till Q3.
Parts already purchased
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341044 850 OCZ power supply 80+gold fully modular
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231518 16 gb of Gskill sniper ram 2133
http://www.newegg.com/Product/Product.aspx?Item=N82E16820171567 120 gb Sandisk SSD (boot/program drive)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136768 750 gb HD for storage
What I need help with:
I have been planning on waiting for Ivy bridge to buy if for no other reason than PCIE 3.0 is natively supported. I have been planning to buy the top of the line graphics card at the time of purchase but it seems like that card is now a mid-range card (if you can consider a $500 card mid-range). I have been considering options for a filler card to buy in May or possibly a justification for buying the gtx 680 or hd 7970 then and leaving it to cf/sli later. What card should I use for filler now or should I just go ahead and buy the best that is available now(I feel like they are overpriced for the minimal gains over other, less expensive options). If i choose a filler card it will be sold when I buy the GK110. Suggestions for the rest of the build are appreciated as well.
Country: USA
