Closed Solved
Help me on how to install a graphics card With power Connectors
Hello Everybody, Can someone please help me on how to Install A graphics card Correct me if im wrong: First unistall all drivers of your own graphics card (Someone help me on that one)--- than Open your computer and pull out the old one and put your new one in Put it all back together turn on and install new drivers from website)
Is that right and also there is Extra power connectors or something on my graphics card how do i plug them all in Please help me Please
Thank you.
24 answers Last reply Best Answer
More about help install graphics card power connectors
  1. You plug your pcie connectors from your power supply to the graphics card. What are you entire system specs and the card you are installing?
  2. More details about my computer
    Component Details Subscore Base score
    Processor Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz 7.3 5.5
    Determined by lowest subscore
    Memory (RAM) 4.00 GB 7.5
    Graphics ATI Radeon HD 5570 5.5
    Gaming graphics 2539 MB Total available graphics memory 6.6
    Primary hard disk 846GB Free (931GB Total) 5.9
    Windows 7 Professional
    System
    Manufacturer Gigabyte Technology Co., Ltd.
    Model H55M-S2V
    Total amount of system memory 4.00 GB RAM
    System type 32-bit operating system
    Number of processor cores 4
    64-bit capable Yes
    Storage
    Total size of hard disk(s) 931 GB
    Disk partition (C:) 846 GB Free (931 GB Total)
    Media drive (D:) CD/DVD
    Graphics
    Display adapter type ATI Radeon HD 5570
    Total available graphics memory 2539 MB
    Dedicated graphics memory 1024 MB
    Dedicated system memory 0 MB
    Shared system memory 1515 MB
    Display adapter driver version 8.920.0.0
    Primary monitor resolution 1360x768
    DirectX version DirectX 10
    Network
    Network Adapter Realtek PCIe GBE Family Controller
    Notes
    The gaming graphics score is based on the primary graphics adapter. If this system has linked or multiple graphics adapters, some software applications may see additional performance benefits.
    ( And the graphics card i am going to get is Geforce Gtx 560 ti Frostr II OC or what ever :)
    And btw It says In here i have directx 10 --- But in DXDIAG i have directX 11 I dont get it? Help please And thank you for replying
    This is the graphics card here: http://www.amazon.com/MSI-PCI-Express-TWIN-FROZR-II/dp/B004JLNZXU/ref=sr_1_fkmr1_1?ie=UTF8&qid=1326771122&sr=8-1-fkmr1
    tell me if it's good Thanks again
  3. Here are some links on how to do what you need to do. I hope these work for you and I wish you luck on your GPU's I was the same way my first time with a GPU.
    http://www.youtube.com/watch?v=xPzjebT3N3U
    http://www.youtube.com/watch?v=O9x097QRXeA
  4. And also my brother said You will have a high chance that you will have to reformat if i install this graphics card is that true?
    Please reply
    Thanks.
  5. Please go slap your brother in the face, he is completely wrong.
  6. Ok And also The video i just looked at Says u need a 6 pin PCI express connector on power supply how do i find that out ??
    please help :(
  8. Hello I just opened my computer up and all i could see coming out of my power supply was loads of all sorts of colour cords and there was white tips and i only had 1! with 6 holes in it the rest were Long 4 hole ones Please Reply fast is this what i need to get this baby working: http://www.amazon.com/MSI-PCI-Express-TWIN-FROZR-II/dp/B004JLNZXU/ref=sr_1_7?ie=UTF8&qid=1326774153&sr=8-7
    and if you look at that card in one of the pics it shows 2 slots with 6 pins i only have 1 white tip 6 pins does that make it so i can't use it now :(
    Thank you so much. :)
  9. What is your PSU?
  10. on your card do you see on the back of it not where you plug in the monitor at the other end you should see where that plugs into as long as your 6 pin connecter is 3 on top of 3 example. If so see if it will plug on the card unless It takes two 4 pin conneters The 4 pin look like the 6 pin but only have 2 on 2 and not in a rowe Like this. . . . . As long as you have the power off then try to plug It in, If they don't want to donot force them.
    V V
  11. My Power Supply is 680 Watts
    And also The card shows in the Picture (PS i dont have the card yet im still waiting To get it) and yer the card shows in the picture Theres
    2 Slots both of them have 6 like this:
    and i looked and in my power supply i only have 1 cord of the 6 pin
    SO if i only plug 1 into the thing will it still work or do i have to have 2 in
    Please Reply and thanks
    HERE IS A BETTER LINK TO TAKE A LOOK AT IT SO YOU CAN SEE THE POWER CONNECTORS: http://au.msi.com/product/vga/N560GTX-Ti-Twin-Frozr-II-OC.html
  12. Is it a modular PSU?
  13. you are saying the 6 pin is 6 pinholes on one row or are they 3 on the top row and 3 on the bottom row it is very inportant they can't be in a strait line. In one of the links it shows a pic of the 6 pin connecter. In that pic the second one after the star trek guy the black end part that is what it is suppose to look like not the two white ends
    Never mind you got it
  14. Find out what your psu is Modulal or not that will take the guessing out of it
  15. I think this might help you a bit, here is a site with information on all of the common connectors associated with power supplies, http://www.playtool.com/pages/psuconnectors/connectors.html
    You require two of these particular type of connectors http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress Since your power supply only has one of these connectors your video card may have come with adapters or you can buy them. This adapter is the second image on the link directly above, it converts 2 of the normal molex 4 pin plugs into a 6 pin pci express connector.
    If you did not receive any of these adapters with your card or your power supply does not have this connector you will need an adapter, http://www.newegg.com/Product/Product.aspx?Item=N82E16812887001
    Simply connect the single pci express 6 pin connector to your video card and get an adapter to power the second connector, you will NEED both.
    In reference to drivers, simply uninstall them all and install the most updated ones from nvidia.com for your card and operating system.
    OK 1. how do i find out what my Modular PSU is and where to look
    2. I only have 1 White tip Connector thing and its 3 holes up top and 3 holes on bottom ok 3 top 3 bottom
    so my question is, is the graphics card im buying shows 2 of those 3 top 3 bottom Connectors on the graphics card i only have 1 Connector in my Computer so if i plug that in will it still work? or do i have to have 2 of them
    Thank you all for helping and replying.
    also My 3 top 3 bottom Connector which makes it 6 pins I only have 1 but do i plug that into it am i talking about the right thing cause its white and Veggetonox gove me a link that shows Black ones? please now im starting to get confused and worried
  17. No it won't, you will need two.
    The connector can be white.
    Modular PSU means the cable is in a bundle and you can unplug them.
    See if you have a PCIe 6+2 pin to go with the 6 pin.
    hello, umm all i have is (1) 6 pin white connector
    And My Cables are in a bundle but they go into my Power supply so i didn't see any plugs for them too....
    Would it be easier if i just went for a graphics card with only 1 6 pin connector and would my computer run it?
    Even know i would've loved to play BF3 in ultra and crysis 2 in ultra :( looks like this isn't going to work
    Thank you for replying Reply please again.
    (!!!! im going to open my pc up one more time to take a look for the Modular PSU stuff Brb Reply
  19. MSI also supply a external 6pin connector with their 560TI gpu you can use this.
  20. Ok everyone i have Opened My Computer And i didnt see anything that you can unplug of the Power supply as all the cords go into the circle inside of it and this is what it is and says:
    Model atx 680 Watts
    680 watts max. power supply pentium 4
    ac input 230v 50hz 5a
    warning Do not remove the cover under any circumstances no services or components inside!
    also look my model up and thats about it so If i do get the External Power cable where would i plug it into ?
    there is a bit more information on the output but i couldn't be bothered writing it down.
  21. Ill make this simple its not rocket science, make sure you have 2 open molex plugs, (these are the 4 pin plugs that look like http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral ) now go buy one of these adapters http://www.newegg.com/Product/Product.aspx?Item=N82E16812887001 and your fine. Once again YOU MUST HAVE both power connectors connected or it will not work.
  22. Best answer
    Model atx 680 Watts
    Hey did you get your problem solved? I was looking at all the answers and they were all very good. I hope all of us here was able to help you. Good luck and have a good time playing on your new card when it gets to you.
  23. Best answer selected by blackwint3r3.
Graphics Cards Drivers Power Graphics Product
