A long story short I started receiving BSODs a while back and haven't been able to figure out the exact cause though I believe it's narrowed to the CPU/mobo.
More details about the machine; http://www.sevenforums.com/crashes-debugging/219481-bsod-stop-0x00000101-stop-0x0000009c.html
Hardware Specs;
CPU; i7 940 at stock speeds I don't like to OC still a newbie
GPU; HiS AMD Radeon 5870
PSU; Zalman 850W
RAM; 8GB, 4gb is patriot G series the other 4gb is g2 series
HDD; 5 Different hard drives I know you're thinking why so many but it was how the PC was built when I bought it and the price for the components seemed right
Mobo; EVGA x58 SLI LE
So it seems the original owner of the PC seems to have OC'ed the CPU near to death before he sold it off to me and it's practically dead now.
Instead of replacing my old CPU for a hefty price I have decided to get a new AMD CPU and motherboard. I was looking for advice on some good CPU/Mobo combos that are well suited together, and not too high in the price range. Budget for the 2 is ~325 total
One motherboard I was looking at was the GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard; http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
Hardware Specs;
PSU; Zalman 850W
