I currently have a computer that never had problems until a bit ago when i got a new program and it runs at 100% usage for about 2.5-3 hours. I then noticed it is idling at 43 celsius and max out at 70ish. I know this is very hot cannot figuring out why its getting that hot i mean i know its running really hard so i expect it but whats the week point. Also fan speed is set to high would disabling cool n quiet in bios help? or adjusting thermal cycling? or is it hardware here is the machine. I have another pc in same room and more powerful stock cooler idles at 23 max is like 49. Added better cooling 5 120mm fans and installed new thermal paste.
ASRock K10N78M-PRO AM3/AM2+/AM2 NVIDIA GeForce 8200 Micro ATX AMD Motherboard
Kingston HyperX T1 Series 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500)
ARCTIC COOLING ACALP64 Pro 92mm CPU Cooler
AMD Phenom 9850 Black Edition 2.5GHz Socket AM2+ 125W Quad
Seagate Barracuda 7200.12 ST3250318AS 250GB 7200 RPM SATA
zotac gt520 video card- problem happened before i installed this
400 watt cooler master psu
used paste from oem first time just replaced yesterday with another brand same problem
Thanks. plus whats rig worth when i get it fixed?
