I am trying to help a friend who has an Apple PC on a wired LAN.
The LAN has a DNS server located elsewhere on the network. His PC is connected directly with what looks like a TIA/EIA-T568B cable.
When his Apple PC is directly wired, the PC gets it's LAN TCP/IP address and other network configuration information fine.
However, the weird stuff starts when I try to add a switch into the mix. When I insert a switch between the PC and the normal LAN connection, I can't get any network configuration information/internet access - although there are flashing lights on the switch for both the LAN and PC connections.
What is going wrong?
Thanks,
AzJazz
Thanks,
AzJazz
