New PC wont even power on?
Parts:
PNY Optima 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model MD8192KD3-1333
XFX Double D Black Edition FX-777A-ZDB4 Radeon HD 7770 GHz Edition 1GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX ...
LG DVD Burner Black SATA Model GH24NS70 - OEM
AMD Athlon II X3 455 Rana 3.3GHz Socket AM3 95W Triple-Core Desktop Processor ADX455WFGMBOX
APEX SK-393-C Black Steel ATX Mid Tower Computer Case
Corsair Nova Series 2 CSSD-V30GB2A 2.5" 30GB SATA II Internal Solid State Drive (SSD)
ASRock 970 EXTREME3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Diablotek DA Series PSDA600 600W ATX12V v2.2 Power Supply
Every thing is hooked up according to what the mother board says. But when I press the power button there is no response the power supply did in fact make all the fans twitch. But that was only once. I am worried that the problem is within the front panel but I am not 100% sure. Please help. Also everything's new. Will install windows 7 Ult when it actually turns on but at this point its not even powering on
7 answers Last reply
More about wont power
  1. Double check to make sure all of the necessary power supply cords are pluged in.
    We all forget some times...:)
  2. Everything is hooked up but, when i press the power button the cpu fans, and the 2 gpu fans rotate like 1/8th of a revolution. But that only happened once now it wont :(
  3. This might sound stupid...but did you connect the pci express connectors to your gpus?
    I'm assuming you did, but I want to double check.
  4. Check for a short somewhere. Could be shorting anywhere in the case, the motherboard standoffs, fan wires, etc.
  5. How would I check for a short? And now when i pressed the power button the led lit up and the fans rotated the same distance but they stopped and There is no display on my monitor though the HDMI
    ^1+ definitely check for a short.
  7. Also the Led is always on when plugged in that doesnt seem right though
Homebuilt DDR3 Desktops Systems
