Solved
Any suggestions for a type power supply upgrade?
  • Power Supplies
  • PCI Express
  • Components
Last response: in Components
July 7, 2012 1:53:45 PM
I have an HP Pavilion Slimline s5 1128p PC. I know this isn't a suitable desktop PC for gaming, but its what someone bought me. I want to use a Radeon HD 6450 PCI-E 2.0 x 16 graphics card. I need a minimum of 400w, I would feel safe with 500w. I'm having trouble deciding what type of power supply is compatible with my motherboard and processor.
Here are my specs:
Motherboard -
Manufacturer: Pegatron
Form factor: uATX: 24.38 cm (9.6 inches) x 24.38 cm (9.6 inches)
Chipset: AMD Hudson-D2 FCH
Memory sockets: 2 x DDR3
Front side bus speeds: 100 MHz UMI (Unified Media Interface)
Processor socket: FM1
Expansion Slots:
PCI-Express Generation 2 speed
1 PCI Express x16
3 PCI Express x1
1 PCI Express Mini Card x1
Processor -
AMD A4-3400 APU with Radeon(tm) HD Graphics 2.70 GHz
Current Power Supply -
Form factor: Internal for slim form factor
Total wattage: 220W
Nominal input voltage range:
100-127V/6A (50-60Hz)
200-240V/3A (50-60Hz)
Dimensions: 200mm x 85mm x 53mm (7.9 x 3.3 x 2.1 inches)
Help would be greatly appreciated! :D
More about : suggestions type power supply upgrade
a b ) Power supply
July 7, 2012 2:00:53 PM
That power supply's dimensions are proprietary. I don't know that you're going to find an aftermarket PSU that'll fit in its place.
m
l
July 7, 2012 2:08:40 PM
Well I found this: Shuttle Computer Shuttle PC63J
Manufacturer Shuttle Computer
Manufacturer Part # PC63J
Cost Central Item # 11368385
Product Description Shuttle PC63J - Power supply ( internal ) - ATX12V 2.3 - 80 PLUS Bronze - AC 100-240 V - 500 Watt - active PFC - for XPC SG41J1, SG41J1 Black Plus, SG41J1 Plus, SG41J1 Plus V2, SH55J2, SX58J3
Device Type Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance ATX12V 2.3
80 PLUS Certification 80 PLUS Bronze
Approximate Dimensions (WxDxH) 3.2 in x 7.9 in x 2.1 in :D
Approximate Weight 2.4 lbs
Input Voltage AC 100-240 V
Output Voltage +3.3, +5, ±12 V
Power Capacity 500 Watt :D
Output connector(s) 1 x power 20 pin ATX
1 x power 8 pin EPS12V with detachable 4 pin ATX12V section
1 x 6 pin PCI Express power
1 x 8 pin PCI Express power with detachable 2 pin section
3 x 15 pin Serial ATA power
2 x 4 pin internal power
1 x 4 pin mini-power connector
I'm confused as to whether the brand of power supply matters in terms of being compatible with my motherboard. Shouldn't I be able to use any power supply as long as its fits?
m
l
July 7, 2012 2:28:06 PM
I posted a power supply that has near perfect dimensions ...
m
l
a b ) Power supply
July 7, 2012 2:34:09 PM
good find! Where'd you find it?
m
l
a b ) Power supply
July 7, 2012 2:37:46 PM
1) Still not convinced that power supply will work
2) The Radeon 6450 is a very low power unit and will probably work with your existing 220w psu. You certainly don't need 500w.
m
l
July 7, 2012 2:47:48 PM
Yea I thought the Radeon would work at first based on some research I did. However 220w is really low and I read that games such as Skyrim wont run well. In order for it to run smoothly, a power supply of 400w is recommended. At least that is what the seller recommended for that specific graphics card.
m
l
Best solution
a c 165 ) Power supply
July 7, 2012 2:55:36 PM
Here are my specs:
minimum 400w is crap. ive installed many ATI/AMD 4350/ 5450/6450 on slim line PCs (make sure you get the low profile card that comes with a low profile bracket). at peak it only uses 26w, at stress a 2500k PC does not break 160w with the amd 6450
July 7, 2012 3:14:56 PM
Best answer selected by OftenConfused.
m
l
