Hello guys, I finished putting my computer components together a few hours ago, and its the first time that i build my computer. Therefore im experiencing some problems with the system and need your help.
1. I think i applied too little amount of AS5 thermal compound but i followed the instructions listed on the AS page with regards to my CPU a i7 2600K. Therefore I just want to monitor the temperature for a while, so what programs you recommend. Im currently using RealTemp 3.70, and have heard that Prime95 is good to test the CPU, but where can i download it from?
2. I have yet not installed the bios/driver CD, that came with my Asus P8Z68 v pro gen3 motherboard, as i have heard it is just better to download the latest bios/driver from the ASUS website. So i went to the site but got lost on finding the bios/driver. Went to this link http://www.asus.com/Motherboards/Intel_Socket_1155/P8Z68V_PROGEN3/#download and selected window 7 X64 bit, and then there is many files to choose from to download. I assume I have to download the latest BIOS file, right? So i did that and when it finished downloading I saw that its a .ROM file, and i've never used that before. So can anyone please direct me on how to get the BIOS for my motherboard.
3. I bought a Sapphire 7950 OC edition, and when I use the driver that I got with the card, it doesn't appear to add anything new to the computer. I check the destination location in the C:/programs/ATI Technologies and there are no files there. So can some please give me a link to the 7950 driver. Oh also tried the one located on the AMD website with the same effect. NOTE however im using a VGA cable connected to the motherboard, so I have actually tried it on the GPU output options because i figured if no new file was added, it would have no effect.
Also when I first got the and inserted it into the PCIe port and still kept the VGA cord in the motherboard outlet, but the when i turned the PC on the monitor wont work. I thought it was a problem with the monitor so tried another one with the same effect. It wasn't until I removed the PSU PCIe cords leading to the 7950 that the screen started to work again.
Also the internet doesn't work on the new PC, but i figured that's because i haven't installed the motherboard BIOS so therefore the Ethernet port isn't working, am i right in this assumption?
Thanks for reading, and hopefully you can help me out.
