Closed Solved
Can my Power Supply Run GTS 450? or any mid range gaming card?
Heres my power supply
http://www.coolermaster.com/product.php?product_id=3738
thank you in advance :D
edit:all my specs
my Motherboard http://ph.asus.com/Motherboards/Intel_Socket_775/P5G41TM_LX3/
Windows 7 enterprise 32bit
intel quad core q6600 @ 2.4ghz
4gig ram kingston
dvd drive? - LG super / multi dvd rewriter 24x
computer casing fans , 2 small ones lol...
im currently using a gt 430 graphics card, im not happy with its performance
sorry if this is the wrong section ,
12 answers Last reply Best Answer
More about power supply range gaming card
  1. I'd say a 6770 to 6850 for an upgrade.
  2. thanks :D, but do you think I can run it with all my specs and power supply?
    +does that card doesnt over heat or something sorry I dont know much ,
    I use nvidia cards for 5 years all of the cards I used before are inno 3d , didnt have any problems with them except that I bought the wrong card last 3 weeks, and thats the gt430 :pfff: cant return it now..
  3. Shame you could of upgraded to a GTX560ti, it would be a great upgrade if you are wishing to stay with nvidia.
    uh, question is, can my specs and power supply run that beast O_O and oh Im off budget lol like 70-80$ what would be a good card for that price?
    thanks by the way :)
  5. imo your psu could use an upgrade e.g. antec neo eco 520c or corsair builder cx v2 500w or seasonic m12ii 620w.
    gt430 is decent for htpc.
    what do you use your pc for? if it's gaming, getting a higher end gfx card would vastly improve gaming experience. check out this gfx card hierarchy chart from tom's:
    http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-7.html
    even a radeon hd 5770/6770 would be a good upgrade from the gt 430.
    if you want to stick with nvidia, the lowest one to go for would be gtx 560 non ti. nvidia doesn't have cards under gtx 560 that perform well for their price. radeon hd 6870 performs similarly to gtx 560 and uses less power on load.
    thank you :love: very well informed
    I always ask this, Can my PSU run the gtx 560? + my over all specs
    edit:and oh Can you recommend a graphics card that is around 70$ that performs great and Can run on my system , Yes I play games my screen resolution is 1024x768
    i dont play at high resolution my monitor isnt that biggy :na:
  7. for $70 you'd be looking at the 6670.
  8. the PSU has 30 amps across its two 12v rails. That's good enough for up to a HD 6780 or GTX 560ti with some safety margin.
    sorry, didn't ask your gaming res. when you mentioned gtx 560, i thought that you play at 1080p resolution.
    depends on your location. you won't find good gaming cards for $70.
    according to newegg, radeon hd 6570 1gb fits your budget and radeon hd 6670 1gb, with a little more. both should be fine for 1024x768 resolution.
    if you run any of these cards and not put much load on your system, the 6570 and 6670 should run okay. it'll come down to how old the psu is as components age, they lose their effectiveness.
    op's psu review:
    http://www.hardwaresecrets.com/article/728
    op's psu review:
    it's ok , thank you mr :love: one last thing , I just called the shop where Im getting the card they have the card ! for my budget and + they are referring a gt440 ddr5 which cost less lol poor me, so..... gt 440 ddr5 or 6670 ddr5? by the way Im getting the 512mb version will I suffer or loose performance and quality ? or not? with 1024x768 resolution?
    @esrever
    yea I just checked , thanks :D
    @ScrewySqrl
    really? :O sucks to know im low at budget ... thanks :)
  11. Best answer
    1 gb gddr5 is better for gaming.
    6670 is better than a gt 440.
    it's like this: gt440 (gddr5) < 5570 (gddr5) < 6570 < 5670 (gddr5) < 6670 (gddr5) (gaming performance)
    the review below has 1024x768 benchmarks and comparison among 5570, gt 440 and 6670.
    http://www.techpowerup.com/reviews/Powercolor/HD_6670/1.html
    if the gt 440 and 6670 are similar in price, 6670 is preferable for it's better performance. just avoid cards with 2 gb vram. extra vram is wasted on these gpus.
  12. Best answer selected by Hushinimi.
Graphics Cards Power Supplies Graphics Product
