I hope this is the right forum. If not, move as needed.
I have a recurring problem with my USB external and/or internal plug-ins. Every now and then - once a month or so - I plug in the USB charger for my MP3 player, phone, or input devices and the computer reboots. When it comes up, the port that I just touched won't work. Sometimes it corrects by just moving to a different external port, but sometimes it requires unplugging from the motherboard and moving to a different header. Eventually the original port/header works again. It does seem to be static electricity, but I'm not sure. I don't know if the static build up is me or if it's coming from the system. I run linux so the system may be up for weeks at a time. The problem occurs randomly - I can be sitting at the computer for hours or just happen to think to recharge something and I get the reboot. If it's the system, which is my main worry, is there something I can do inside the case to check it? This mostly happens on the external front panel USB ports (both the case ports and a 3.5" card reader). I want to get this fixed before something bad happens.
Asus M4A88TD-M/USB3
AMD 555BE (X2 unlocked to X4)
Arctic Cooling Freezer 7 Pro
2x2GB Corsair XMS 1333 D3
Antec Neo 500W (modular)
Asus DRW 24-B1ST
EVGA GeForce 8600GTS
Rosewill Gear X3 case
Ubuntu 11.10 Ocelot
Asus M4A88TD-M/USB3
Asus DRW 24-B1ST
Ubuntu 11.10 Ocelot
