Tom's Hardware > Forum > Digital Camera > Digital Camera General > KonicaMinolta Z5 USB Problem
Forum Digital Camera : Digital Camera General - KonicaMinolta Z5 USB Problem
Archived from groups: rec.photo.digital (More info?)
Trying to connect the Z5 to a PC with Windows 2000 and it doesn't detect
it. The cable is OK. The Konica website says there can be conflicts with
other USB devices, so this has obviously happened before.
I have disconnected all USB's except the mouse but when I connect the
camera it says driver not installed. It won't detect it from the CD.
Anyone come across this before?
Robert
Sponsored Links
I have a Mac with OS X and my Z5 connects to my Mac instantly.
On WIndows machines you need the viewer software. You should go to:
http://kmpi.konicaminolta.us/epris [...] upportCent
er/SoftwareResults
and download the Windows 2000 viewer software:
DiMAGE Viewer Software Update Ver. 2.3.7 - Win
and install it.
Pardon my spam deterrent; send email to rhodyman@earthlink.net
Cheers, Steve Henning in Reading, PA USA
http://home.earthlink.net/~rhodyman
Reply to Anonymous
> er/SoftwareResults
> and install it.
Hi,
Is your W2k with all the updates? I run W2K Sp4 with a few different
cameras, scanners, etc. on USB. No problem ever.
Try to find the camera from device manager then by forcing it.
There must be a CD which came with the camera for it's specific needs if
there is any. Also does your PC have latest BIOS?
Tony
Reply to Anonymous
- 0 +
> Hi,
> if there is any. Also does your PC have latest BIOS?
> Tony
I have loaded the DiImage update from the website, I will check the windows
2000 updates and try again
Thanks
Reply to RH
There are 1217 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
