Need help with psu power for my build?
Last response: in Components
hi i dont know how much power watts do i need ,and i dont want to overprice it maybe you you know how much i need this is my build
i7 3770k
sabertooh z77
gtxx 680
16gb rams
samsung spinpoint f3 1tb
samsung 830 ssd 128gb
asus xonar stx sound card
i will only be using one gtx 680. i maybe will oc the cpu:)
is 850w overkill? how much do i need to dont have any problem and run everything cool?:) ))
thanks
More about : psu power build
Power supply Master
a quality 550w+ (43a+ on the 12v rail) will be more then enough, you will be around 350w total system power while gaming
Core i7 Test System Specs
- Intel Core i7-3960X Extreme Edition (3.30GHz)
- x4 2GB G.Skill DDR3-1600(CAS 8-8-8-20)
- Gigabyte G1.Assassin2 (Intel X79)
First, newer components take less power than older ones, so you don't need as much power as you might think.
Second, by quality brand ct meant something like corsair, seasonic, or antec. Alpine is not a quality brand. Look for a powers supply that is 80plus (bronze, silver, gold, or platinum) certified.
550w should be enough, but you could get a little more if you're overclocking.
Related ressources
Power supply Master
karolis said:
i remeber when i have the amd thlon x4 .4gb ram gtx 560ti and 650w psu but the brand was alpine. and the psu just burn. so how 550w is inaf for that build?
because a quality 550w PSU will offer 550w continuously and peak above that mark and a cheap 550w unit will basically call it quits at 325w like yours did since with those specs, your probably never broke 325w.
for $50, you won't find a better PSU
http://www.performance-pcs.com/catalog/index.php?main_p...
Ask the community
