Hello,
I need some help with making a PC based around playing MMORPG's.
I will mainly be playing TERA and SWTOR and I believe they both have pretty demanding system requirements.
Can you guys give me some help on what parts will be best to use in building a PC based around these games. I have a budget of $1000.
For reference, here are the system requirements for both games:
The recommended system requirements for TERA:
• OS: Windows XP, VISTA or 7 (Latest Service Pack)
• CPU: AMD Athlon 64 X2 6000+ or Intel Core2 Duo E6750 2.66G
• RAM: 2 GB or greater
• GPU: AMD Radeon HD 3870 or Geforce 8800GT
• HDD: 30 GB of hard drive space
• DirectX: DirectX 9.0c
• Optical Drive: DVD-ROM Drive
• Internet Connection
The recommended system requirements for TOR:
CPU: AMD Phenom 2 X4 Quad-core 2.5GHz or better / Intel Core 2Quad Processor 2.4GHz or better.
OS: Windows 7 64bit SP1, with 4GB RAM or higher.
8x DVD-ROM or faster.
VIDEO: ATI/AMD Radeon HD 4850 or better* / NVIDIA GeForce GTX 260 or better* / *512 minimum video RAM / *Shader 3.0 or better fully compatible graphics card.
Thanks guys!
Thanks guys!
