Will my Power Supply work for all this
1 answer Last reply
More about will power supply work this
  1. Hello TackyFruit :hello:
    Ok lets start with the motherboard not having the right socket for the CPU, your CPU has an AM3 socket, your MoBo FM1, this is a no go. now if your staying with the FX-4170 Zambezi you need a MoBo with a AM3 socket like this one.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813135272 I've never used this brand but they have a good rating in NewEgg which is pretty reliable plus its less than the one you had picked out leaving room for other parts.
    Now for the GPU (Although AMD Radeon 6870, not Nvidia) XFX has a deal on one right now 2Gb 256 bit for $190 plus a free Dirt 3 game after MIR here. http://www.newegg.com/Product/Product.aspx?Item=N82E16814150563
    Now the Power supply, you might be able to EEEEKK by with the 500W you proposed but here more is better especially if you are going to upgrade this in the future, like SLI'd video card or overclocking your CPU. I would go with something more like this for a PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817553010 it's Bronze rated and $69 right now after MIR.
    Now for the aftermarket heat-sink, if you plan on overclocking I would recommend this http://www.newegg.com/Product/Product.aspx?Item=N82E16835118019 if not the factory heat-sink would be fine, remember they designed the factory heat-sink to work with the processor within normal operating parameters.
    Now DON"T buy that Toshiba HDD, OMG its J U N K ! 5400RPM? Useless! for the price range your shooting at go with this http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697 It is a 1Tb (same as both your drives combined) 7200RPM with a 32MB(Double your pic's) Cache. All this equates to faster access time all around with a single drive that costs less than your 2 combined.
    Plain and simple the memory you posted is OK, this is better http://www.newegg.com/Product/Product.aspx?Item=N82E16820233180 for $8 bucks more.
    I think for that case I would get 2 120mm fans (One top and one back) because it only comes with 1 and that GPU and CPU are going to need some air. Maybe like these cheap
    If you like white $4.99 each
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835200051
    If you like blue $7.99 each
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835200049
    Just my 2 cents do with it what you will.
New Build Power Supplies CPUs Systems Product
