POWER SUPPLY
  • Power Supplies
  • Cooler Master
  • Corsair
  • Components
Last response: in Components
July 10, 2012 3:21:17 AM
which better huntkey 1200w x-7 / cooler master 1200w silent pro / corsair 1200w ???
pls share the suggestion and information..
wanna use 2 gpu card n i7 3770k
More about : power supply
a c 298 ) Power supply
July 10, 2012 3:35:09 AM
The corsair AX 1200 is top notch, its also priced as such, it has excellent voltage stability, excellent ripple suppression, and excellent efficiency
http://www.jonnyguru.com/modules.php?name=NDReviews&op=...
The Cooler Master Silent Pro Gold 1200 W is of lesser quality and priced lower, it has excellent voltage stability, below average ripple suppression, and good efficiency though it can only hold 80+ silver at higher temperatures
Huntkey, ohh what is there to say about huntkey...
Well at least it is one of their best power supply units, but they didn't send any models out for real reviews by the major power supply review sites, and being huntkey's best power supply model doesn't mean much when their average does this
http://www.hardwaresecrets.com/article/Huntkey-Green-St...
m
l
a b ) Power supply
July 10, 2012 6:06:24 AM
To be fair, not all of the explode...just most of them.
The real question is: do you need this much power? What gpu are you getting?
m
l
July 21, 2012 11:39:22 AM
yeah, im sure for 1200w, just bought it (AX1200w)...
i wanna make setting the tri/dual SLI mode gpu card (dont know yet what gpu wanna use ) and overclocking too,
what i got now is :
- asus maximus IV extreme-z 1155
- corsair dominator gt 1866 quad channel (16gb)
- corsair AX1200w
next : intel i7 3770k
sory, im noob in this topic but day by day im researching and refer to the exprience one..
so what do suggest to me..any?me no problem
thnks alot by JARD
m
l
a b ) Power supply
July 21, 2012 2:27:55 PM
seasonic 1000 platnium is all you need the new cards aint power hungry and 1200watts can do quad sli gtx 680's 650watts can run sli gtx680's and 1000 watts will run 3 way with room to spare
m
l
