Best Power Supply
  • Power Supplies
  • Intel i5
  • Corsair
  • Components
  • Product
Last response: in Components
July 10, 2012 1:40:27 PM
Hi what would be the best power supply for my specs
Intel I5 2500k
Corsair 8 GIGs RAM
Asus Maximus IV Gene
EVGA GTX 560 TI Classified
NZXT Phantom Case
More about : power supply
July 10, 2012 1:48:25 PM
If you aren't doing SLI then you will be pushing near 500 on max load. I'd go for around 550w to be on the safe side. Preferably a silver rated power supply, but bronze will do just as well.
Here is a 80 plus bronze to check.
Here is a silver, about $20 more.
Not familiar with the brand for the silver powersupply. I usually stick to SeaSonic, Corsair, or XFX.
m
l
a c 158 ) Power supply
July 10, 2012 2:19:42 PM
AMD specifies a 550W PSU for a system with a single GTX 560ti; the PSU should have at least 36A on the 12V rails and two 75W 6-pin PCIe power connectors. Amperage on the 12V rails is more important than the total wattage rating of the PSU; most power draw from modern PCs is on the 12V rails. Real world power draw for a 560ti system is not likely to exceed the 319W drawn by this system with a highly OCd, power-hungry i7 965: http://www.guru3d.com/article/geforce-gtx-560-ti-review... The Seasonic M12II 520W is an excellent PSU; it's 40A on the 12V rails capable of running the above system and has sufficient power overhead for moderate OCing.
m
l
