Well I finally got some money and I am going to try to my hand at building my own system because I heard it's cheaper by a bit. I need a gaming desktop that will last for about 4 years playing the most demanding games on high graphics.
Budget:$2500(With this I can probably buy a factory built one but where's the fun in that )?
I might have to upgrade later so for now my effective budget is around 1800
Optical Drive: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1387814&Sku=O451-1030%20OEM
Power supply: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5683590&CatId=2535
It might seem overkill but I might upgrade to Crossfire later.
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115095
Case:http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
Memory: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7025812&CatId=3473
Motherboard:http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1125284&CatId=7212
OR
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
Hard Drive:http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1310560&CatId=4357
Video Card:http://www.newegg.com/Product/Product.aspx?Item=N82E16814125419
OR
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102984
OR
Crossfire:http://www.newegg.com/Product/Product.aspx?Item=N82E16814161363
Monitor:http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=457461&CatId=5469
Please tell me if any can be upgraded or downgraded to better suit my needs.Big thanks in advance!
OR
OR
OR
