Hi guys, I know there's lost of posts like this, but I'm not too sure if these parts are compatible.
(This is supposed to be a low end gaming build):
AMD Athlon II X2 Dual Core 260 (AM3)
Gigabyte GA-970A-D3 Mainboard AM3+
Corsair 4GB DDR3 PC-10600/1333 RAM
ATI Radeon HD 6850 1GB
Seagate Barracuda 500GB HDD @ 7200RPM
LG DVD Burner
Asus PCE N10 (Wireless Network Adapter)
Thermaltake Litepower 600W
Case - ATX Full Tower case.
I'm pretty sure about most of them, but I'm mostly worried about compatibility between the CPU and the RAM.
AMD says that the Athlon II can only handle RAM up to DDR3 1066MHZ, but the RAM I'm getting is DDR3 1333MHZ. Will it still work together though?
If they won't work, do you guys have any suggestions?
My budget is around $800 AUD.
Thanks!
Billy
LG DVD Burner
Thanks!
Billy
