Dial-up problem
Inferno
149
After the last restart of the system, Network and Dial-up connections folder stopped showing connections. Even the shortcuts from the desktop don't work anymore. I didn't change anything to the hardware, or software. The connections are still there, because I can connect to the net using IE6 connection dialog, but once connected, it doesn't show that dial-up icon in the tray... When I try to make a new connection, it works, and it makes it (shown in IE6 dialog), but even the new connection isn't visible in Network dialog. Any way to reinstall Dial-up?
G
Guest
Guest
I could try to answer your question but why should I when you didn't bother to enter ANY information in your profile.
Like you, the answer will remain anonymous.
Inferno
149
The last time I checked, this forum was based on a volontery basis. If you can help me, please do, and thank you in advance. If you can't, please take your attitude somwhere else. Thank you...
Arrow
Splendid
Dec 31, 2007
4,123
I think it's in the Add/Remove Windows components area.
Rob
Please visit <b><A HREF="http://www.ncix.com/canada/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/canada/index.cfm?affiliateid=319048</A></b>
