Solved
BUYING POWER SUPPLY NEED HELP!
  • Power Supplies
  • Graphics Cards
  • Components
Last response: in Components
July 10, 2012 9:52:57 PM
Right away my buget is 50$ for this PSU
I need the best PSU out there for this budget that has 2x6pin pciexpress connectors because my Graphics cards needs that.
Thank you!
More about : buying power supply
July 10, 2012 9:53:13 PM
around 500 W would be perfect
m
l
a c 158 ) Power supply
a b U Graphics card
July 10, 2012 10:01:57 PM
Buying in the US? Are rebates acceptable to get you to $50 or do you need the checkout price to be $50? Does the $50 price have to include the cost of shipping? Any wiggle room in the price? What are your system specs?
m
l
July 10, 2012 10:08:19 PM
Yes buying in the US, i dont really like rebates but if it is a good rebate i can probly go for it but try to avoid it. & idk about shipping is there anycodes for newegg, tigerdirect or anyother websites that can get free shipping?
m
l
Best solution
a b U Graphics card
July 10, 2012 10:19:03 PM
Without knowing your system specs it's difficult to gauge if recommendations fit your build. A short list of potential recommendations listed in order:
1. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
2. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
3. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
4. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
July 10, 2012 10:20:45 PM
Best answer selected by hubict12.
m
l
July 10, 2012 10:25:52 PM
thanks for the PSU's
One more questions. The graphics card that i ordered is Geforce GTX 460 1GB
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=...
When i checked the graphics card system requirements it said that it needs atleast 450W and Power Connector 2x 6 pin, i dont really understand that. does that mean that the PSU needs to have that or something else can u explain it?
m
l
a b U Graphics card
July 11, 2012 10:38:20 AM
The GPU mfr is simply stating that a PC with a GTX 460 should have at least a 450W PSU. The GPU doesn't require a 450W PSU; the entire PC. This is an estimate from the mfr and is usually overly safe. Safe to limit liability to the GPU mfrs; they know there are a lot of shoddy PSUs on the street and they over-estimate so the PSU operates at lower operational loads. All of the PSUs that I recommended were at least 500W so we're good there and all of them also have at least two PCIe power connectors; a combo of either a 6-pin or a a 6+2 pin. A 6+2 pin connector can act as either a 75W 6-pin PCIe power connector or as a 150W 8-pin PCIe power connector.
m
l
