I just built a new PC for a friend and all seemed to be going well until it started booting up with a black screen with a blinking cursor. My first guess was boot order but SSD was priority. So now I'm thinking not enough power but I thought I did the math right and he still had about a 100w over head. So I'm reaching out to the community to see what you guys think. Like I said it loads gets past the bios setup and right when windows is supposed to load it just goes black with a blinking cursor.
This is the build....
-Rosewill BLACKHAWK Gaming ATX Mid Tower Computer Case, come with Five Fans(3 led 120mm)
-ASUS P8P67 PRO (REV 3.1) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
-Intel Core i5-2500K Sandy Bridge 3.3GHz LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000
-G.SKILL Sniper Low Voltage Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
-OCZ Agility 3 AGT3-25SAT3-60G 2.5" 60GB SATA III MLC Internal Solid State Drive (SSD) (Operating System)
-Western Digital Caviar Blue 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s
-ASUS Radeon HD 6770 1GB 128-bit GDDR5
-CORSAIR Hydro Series H60
-LG 22X Super-Multi DVD Burner 22X DVD+R 8X DVD+RW 8X DVD+R DL 22X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM
-CORSAIR Enthusiast Series TX550M 550W ATX12V v2.31 / EPS12V v2.92 80 PLUS BRONZE Certified Power Supply
Software....
-Windows 7 Ultimate 64bit
Once again thank you for your input on the matter and any advice is greatly appreciated.
Software....
