Help in building gaming pc
beastwolf
60
hey guys i am building mah first gaming pc
mah budget is 750$ - 850$
i have great confusion amongst various components
1) GPU - i have chosen nvidia gtx 560 ti 2 gb . but i am not confident that dis card will last for 4 yrs coz i will not be able to upgrade anyhow before 4 yrs .
ALSO IF SOMEONE CAN TELL ME IF GTX 560 TI 448 CORES IS AVAILABLE IN INDIA
2) RESOLUTION - i can decide as what resolution should i choose . am confused between 1680*1050 and 1920*1080 . i know that i will get better fps in 1680*1050 but i think that mah gpu i enough for 1920*1080 but i am not confident
3) VRAM - i know that more vram i needed for more resolution so am considering 2gb for 1920*1080 annd 1 gb for 1680*1050 . but again not confident
4) OC MOBO - HERe in india not much mobo is available or i knownt know abt them but any suggestion will be highly appreciated
5) PSU - 650w will be enough ??
tell u that will not be doing sli in future and rest config.
intel i5 2500k
500gb hdd
4 gb 1333mhz
PLZ HELP GUYS I WILL BE BUYING MAH PC IN NXT 10 DAYS OR SO
truegenius
BANNED
extra cores helps in video,photo,rendring. But not much in gaming, gaming needs fast cores not multiple slow cuda cores.
cpu for Rs 12-13k
i5-2500k
mobo for Rs 12-13k
ASUS Maximus IV GENE-Z (8+4+2 phase design)
RAM for Rs 3k
2x4gb corsair vangeance 1600mhz cl9 @1.5v
for gpu, i say wait, but if you can't then
gpu for Rs 15-16k
MSI R6950 Twin Frozr III Power Edition/OC
it is better than 560 and is near 570, also overclockable to more than 1000/6000mhz
if you are buying that gpu then a psu with 45A on 12v (means atleast 550 on 12v) that makes the psu to a 650w of total power.
