Crashing system help
My system has started regularly crashing (freezing) for the last few months and I can't find out why. The system basically just completely freezes and I must reboot.
It is pretty random, it usually only happens every few days, but can happen several times a day.
The thing I have found which seems to be able to cause it in windows is watching video.
I have ruled out windows as the cause though as it happens outside of windows as well.
I have replaced the drives.
tried different 2 different gfx cards in different sockets.
run memtest on my RAM overnight with no errors reported
The motherboard is an ASUS P5QPro Turbo
nothing in this machine is more than 18 months old.
I don't have a spare PSU or CPU to test if these are the cause and have reached the point where I feel I have wasted enough time and money trying to find the cause now, so am on the verge of giving up and buying a new system from Chillblast.com
can anyone suggest any other tips to find the cause that wont involve me spending more money.
22 answers Last reply
More about crashing system help
    Sounds like a PSU problem to me. If you don't have access to one for testing then we won't know. I doubt it's the CPU (though I don't know what it is). You've eliminated the RAM as a problem. Anything could be the problem of course - but I wouldn't trash an 18 month old system for this problem.
  2. +1 to Chaz, it does sound like the PSU or it could be overheating.
    maybe even a drivers issue.
  3. is there any way to test the PSU or CPU for faults without buying a new one, sorry if that seems like s dump question but i'm not an engineer so don't have testing equipment etc.
    problem is I am spending so much money replacing all the components already when there was nothing wrong with them, which is just wasting money as I can't use them for anything now, i'm going to end up with a whole new system at this rate :-) thus why I thought I was better off buying a new branded system with RTB warranty.
  4. Here is a link to a step by step tutorial on testing your PSU without a PSU tester
    http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
  5. I ordered a psu tester from amazon, only £10 :-)
  6. Let us know how it goes :)
    Bless your patience to wait for that!
  8. I have put up with this problem for weeks already, a few more days wont hurt :-)
  9. hmm,a ctually it seems it might not be hardware related.
    I tried running windows in safe mode for a few days, no crashed.
    Ran Ubuntu off USB for a few days, no crashes.
    So seems like it is windows/driver related.
    This makes it more odd, because I did a complete clean install of windows to try and resolve the issue, and all my drivers are up to date. I have also installed official/latest nvidia drivers in case of video issues seeing as that seems to cause crashes fairly often.
    Then I assume 'I have ruled out windows as the cause though as it happens outside of windows as well" is no longer valid. Can you still cause it by watching video's?
  11. causing it by watching videos is very random, sometimes it will happen and sometimes not.
    I do not have any 100% way to reproduce.
    I leave my system on 24/7, and most times it will crash overnight when not in use, especially after the weekend. During this time it is of course not in use and under no kind of load.
    I left my system running ubuntu since Friday, so far it has not crashed. I did not get it to crash when watching video on ubuntu so far.
    The reason I had ruled out windows previously is because I left the system on the bios screen over the weekend, and come Monday morning and even that had crashed, but perhaps that was a fluke? it is very hard to say with it being so random.
  12. PSU tester arrived today and says my PSU is fine.
    system had crashed again of course, and today issue is systematically constant, at least this time I have seen an obvious cause, whenever I visited a webpage that had anything graphics/video related then the system crashed. e.g.
    www.speedtest.net
    the flash on this page seemed to crash the system every time.
    I have used msconfig to disable everything except windows services and am running like this now to see if it reoccurs, although not sure how to determine which driver is the cause if that is the case.
  13. Are all of your drivers up to date?
  14. windows update is up to date, and nothing pending.
  15. Let's go back to the basics. List your system for us - What CPU are you using? What RAM? What are your Bios settings?
  16. Intel Core2 Quad Q6700 Socket 775 LGA
    8GB Corsair DDR2 (PC2-6400)
    BIOS Properties
    BIOS Vendor American Megatrends Inc.
    Serial Number Syst-em-
    BIOS Version 0602
    Firmware Version
    BIOS Date 08/04/2009
    BIOS Size 1024 KB
    BIOS Starting Segment F000h
    DMI Version 2.5
    Characteristics
    supports ISA Yes
    supports MCA No
    supports EISA No
    supports PCI Yes
    supports PC Card (PCMCIA) No
    supports Plug-and-Play Yes
    supports APM Yes
    upgradeable (Flash) BIOS Yes
    allows BIOS shadowing Yes
    supports VL-VESA No
    ESCD support is available Yes
    supports booting from CD-ROM Yes
    supports selectable boot Yes
    BIOS ROM is socketed Yes
    supports booting from PC Card (PCMCIA) No
    supports Enhanced Disk Drive specification Yes
    supports INT 13 for Japanese NEC 9800 1.2M floppy (3.5-inch, 1024-byte sectors, 360rpm) No
    supports INT 13 for Japanese Toshiba 1.2M floppy (3.5-inch, 360rpm) No
    supports INT 13 5.25-inch/360K floppy services No
    supports INT 13 5.25-inch/1.2M floppy services Yes
    supports INT 13 3.5-inch/720K floppy services Yes
    supports INT 13 3.5-inch/2.88M floppy services Yes
    supports INT 05 print-screen Yes
    supports INT 09 and 8042 keyboard services Yes
    supports INT 14 serial services Yes
    supports INT 17 printer services Yes
    supports INT 10 CGA/Mono video services Yes
    NEC PC-98 No
    supports ACPI Yes
    supports legacy USB Yes
    supports AGP No
    supports booting from I2O device No
    supports booting from LS-120 Yes
    supports booting from ATAPI ZIP drive Yes
    supports booting from IEEE 1394 device No
    Smart Battery supported No
    BIOS Boot Specification supported Yes
    Function key-initiated Network Service boot supported No
    Enable Targeted Content Distribution Yes
    ACPI
    APIC A_M_I_ OEMAPIC
    FACP A_M_I_ OEMFACP
    HPET A_M_I_ OEMHPET
    MCFG A_M_I_ OEMMCFG
    OEMB A_M_I_ AMI_OEM
    OSFR A_M_I_ OEMOSFR
    SSDT DpgPmm CpuPm
    what about your graphics drivers, whats graphics card(s) do you have?
  18. Property Value
    REDDWARF
    Video Adapter Radeon HD 4670
    Code Name RV730
    Video Processor ATI display adapter (0x9490)
    Technology 55 nm
    Adapter DAC Type Internal DAC(400MHz)
    PCI ID 0x1002 / 0x9490 (Advanced Micro Devices [AMD] nee ATI / RV730XT [Radeon HD 4670])
    PCI sub ID 0x174B / 0xE100 (PC Partner Limited / RV730XT [Radeon HD 4670])
    Memory 512 MBytes
    Memory Bus Width 128 bits
    Dedicated Video Memory 501 MB (525340672)
    Dedicated System Memory 0 MB (0)
    Shared System Memory 3839 MB (4026017792)
    BIOS Date 08/10/09
    PnP Device Id PCI\VEN_1002&DEV_9490&SUBSYS_E100174B&REV_00\4&39043ADE&0&0008
    Video Mode Description 1680 x 1050 x 4294967296 colors
    Driver Version 8.950.0.0
    Driver Date 2012-02-14 00:00:00
    DirectX DirectX 11
    Driver Name aticfx32.dll
    Driver Description ATI Radeon HD 4600 Series
    Monitor Generic PnP Monitor
    Model M2294D-PZ
    Monitor ID GSM56B1
    Manufacturing Date 2008, Week 11
    PnP Device Id DISPLAY\GSM56B1\5&1DA654E1&1&UID513
    Input Digital
    Display Size 22.0" (47 cm x 30 cm)
    Horizontal Frequency 30-83 kHz
    Vertical Frequency 56-75 Hz
    Current Resolution 1680 x 1050 @ 60 Hz
    Supported Resolution 1680 x 1050 @ 60 Hz - Aspect Ratio 16:10
    Supported Resolution 1280 x 1024 @ 60 Hz - Aspect Ratio 5:4
    Supported Resolution 1280 x 960 @ 60 Hz - Aspect Ratio 4:3
    Supported Resolution 1152 x 864 @ 75 Hz - Aspect Ratio 4:3
    Supported Resolution 1440 x 900 @ 60 Hz - Aspect Ratio 16:10
    EDID Version 1 revision 3
    Max dot clock (video bandwidth) 150 MHz
    DPMS Mode Support Active Off, Suspend, Standby
    Monitor ID GSM5774
    Manufacturing Date 2009, Week 1
    PnP Device Id DISPLAY\GSM5774\5&1DA654E1&1&UID515
    Input Analog Input Voltage - 0.700V/0.000V
    Display Size 21.7" (48 cm x 27 cm)
    Supported Resolution 1920 x 1080 @ 60 Hz - Aspect Ratio 16:9
    Supported Resolution 1280 x 1024 @ 75 Hz - Aspect Ratio 5:4
    Supported Resolution 1152 x 864 @ 60 Hz - Aspect Ratio 4:3
    Supported Resolution 1280 x 960 @ 75 Hz - Aspect Ratio 4:3
    Max dot clock (video bandwidth) 170 MHz
    Display Device \\.\DISPLAY1
    Device Name ATI Radeon HD 4600 Series
    Device Key \Registry\Machine\System\CurrentControlSet\Control\Video\{232FBBDC-F0A2-45FE-9BBA-BC413A8C22C0}\0000
    Device Flags DISPLAY_DEVICE_ACTIVE, DISPLAY_DEVICE_MODESPRUNED, DISPLAY_DEVICE_PRIMARY_DEVICE
    Video Modes
    Current Mode 0 640x 480 (8 bits) 256 59 Hz
    Supported Mode 1 640x 480 (8 bits) 256 60 Hz
    Supported Mode 2 640x 480 (8 bits) 256 75 Hz
    Supported Mode 3 640x 480 (16 bits) 64K 59 Hz
    Supported Mode 4 640x 480 (16 bits) 64K 60 Hz
    Supported Mode 5 640x 480 (16 bits) 64K 75 Hz
    Supported Mode 6 640x 480 (32 bits) 4096M (True Color) 59 Hz
    Supported Mode 7 640x 480 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 8 640x 480 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 9 720x 480 (8 bits) 256 60 Hz
    Supported Mode 10 720x 480 (8 bits) 256 60 Hz
    Supported Mode 11 720x 480 (8 bits) 256 60 Hz
    Supported Mode 12 720x 480 (16 bits) 64K 60 Hz
    Supported Mode 13 720x 480 (16 bits) 64K 60 Hz
    Supported Mode 14 720x 480 (16 bits) 64K 60 Hz
    Supported Mode 15 720x 480 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 16 720x 480 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 17 720x 480 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 18 720x 576 (8 bits) 256 60 Hz
    Supported Mode 19 720x 576 (8 bits) 256 60 Hz
    Supported Mode 20 720x 576 (8 bits) 256 60 Hz
    Supported Mode 21 720x 576 (16 bits) 64K 60 Hz
    Supported Mode 22 720x 576 (16 bits) 64K 60 Hz
    Supported Mode 23 720x 576 (16 bits) 64K 60 Hz
    Supported Mode 24 720x 576 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 25 720x 576 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 26 720x 576 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 27 800x 600 (8 bits) 256 56 Hz
    Supported Mode 28 800x 600 (8 bits) 256 60 Hz
    Supported Mode 29 800x 600 (8 bits) 256 75 Hz
    Supported Mode 30 800x 600 (16 bits) 64K 56 Hz
    Supported Mode 31 800x 600 (16 bits) 64K 60 Hz
    Supported Mode 32 800x 600 (16 bits) 64K 75 Hz
    Supported Mode 33 800x 600 (32 bits) 4096M (True Color) 56 Hz
    Supported Mode 34 800x 600 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 35 800x 600 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 36 848x 480 (8 bits) 256 60 Hz
    Supported Mode 37 848x 480 (8 bits) 256 60 Hz
    Supported Mode 38 848x 480 (8 bits) 256 60 Hz
    Supported Mode 39 848x 480 (16 bits) 64K 60 Hz
    Supported Mode 40 848x 480 (16 bits) 64K 60 Hz
    Supported Mode 41 848x 480 (16 bits) 64K 60 Hz
    Supported Mode 42 848x 480 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 43 848x 480 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 44 848x 480 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 45 1024x 768 (8 bits) 256 60 Hz
    Supported Mode 46 1024x 768 (8 bits) 256 75 Hz
    Supported Mode 47 1024x 768 (16 bits) 64K 60 Hz
    Supported Mode 48 1024x 768 (16 bits) 64K 75 Hz
    Supported Mode 49 1024x 768 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 50 1024x 768 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 51 1152x 648 (8 bits) 256 60 Hz
    Supported Mode 52 1152x 648 (8 bits) 256 60 Hz
    Supported Mode 53 1152x 648 (8 bits) 256 60 Hz
    Supported Mode 54 1152x 648 (16 bits) 64K 60 Hz
    Supported Mode 55 1152x 648 (16 bits) 64K 60 Hz
    Supported Mode 56 1152x 648 (16 bits) 64K 60 Hz
    Supported Mode 57 1152x 648 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 58 1152x 648 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 59 1152x 648 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 60 1152x 864 (8 bits) 256 60 Hz
    Supported Mode 61 1152x 864 (8 bits) 256 60 Hz
    Supported Mode 62 1152x 864 (8 bits) 256 60 Hz
    Supported Mode 63 1152x 864 (8 bits) 256 75 Hz
    Supported Mode 64 1152x 864 (16 bits) 64K 60 Hz
    Supported Mode 65 1152x 864 (16 bits) 64K 60 Hz
    Supported Mode 66 1152x 864 (16 bits) 64K 60 Hz
    Supported Mode 67 1152x 864 (16 bits) 64K 75 Hz
    Supported Mode 68 1152x 864 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 69 1152x 864 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 70 1152x 864 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 71 1152x 864 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 72 1280x 720 (8 bits) 256 60 Hz
    Supported Mode 73 1280x 720 (8 bits) 256 60 Hz
    Supported Mode 74 1280x 720 (8 bits) 256 60 Hz
    Supported Mode 75 1280x 720 (16 bits) 64K 60 Hz
    Supported Mode 76 1280x 720 (16 bits) 64K 60 Hz
    Supported Mode 77 1280x 720 (16 bits) 64K 60 Hz
    Supported Mode 78 1280x 720 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 79 1280x 720 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 80 1280x 720 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 81 1280x 768 (8 bits) 256 60 Hz
    Supported Mode 82 1280x 768 (8 bits) 256 60 Hz
    Supported Mode 83 1280x 768 (8 bits) 256 60 Hz
    Supported Mode 84 1280x 768 (16 bits) 64K 60 Hz
    Supported Mode 85 1280x 768 (16 bits) 64K 60 Hz
    Supported Mode 86 1280x 768 (16 bits) 64K 60 Hz
    Supported Mode 87 1280x 768 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 88 1280x 768 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 89 1280x 768 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 90 1280x 800 (8 bits) 256 60 Hz
    Supported Mode 91 1280x 800 (8 bits) 256 60 Hz
    Supported Mode 92 1280x 800 (8 bits) 256 60 Hz
    Supported Mode 93 1280x 800 (16 bits) 64K 60 Hz
    Supported Mode 94 1280x 800 (16 bits) 64K 60 Hz
    Supported Mode 95 1280x 800 (16 bits) 64K 60 Hz
    Supported Mode 96 1280x 800 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 97 1280x 800 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 98 1280x 800 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 99 1280x 960 (8 bits) 256 60 Hz
    Supported Mode 100 1280x 960 (16 bits) 64K 60 Hz
    Supported Mode 101 1280x 960 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 102 1280x1024 (8 bits) 256 60 Hz
    Supported Mode 103 1280x1024 (8 bits) 256 75 Hz
    Supported Mode 104 1280x1024 (16 bits) 64K 60 Hz
    Supported Mode 105 1280x1024 (16 bits) 64K 75 Hz
    Supported Mode 106 1280x1024 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 107 1280x1024 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 108 1360x 768 (8 bits) 256 60 Hz
    Supported Mode 109 1360x 768 (8 bits) 256 60 Hz
    Supported Mode 110 1360x 768 (8 bits) 256 60 Hz
    Supported Mode 111 1360x 768 (16 bits) 64K 60 Hz
    Supported Mode 112 1360x 768 (16 bits) 64K 60 Hz
    Supported Mode 113 1360x 768 (16 bits) 64K 60 Hz
    Supported Mode 114 1360x 768 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 115 1360x 768 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 116 1360x 768 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 117 1360x1024 (8 bits) 256 60 Hz
    Supported Mode 118 1360x1024 (8 bits) 256 60 Hz
    Supported Mode 119 1360x1024 (8 bits) 256 60 Hz
    Supported Mode 120 1360x1024 (16 bits) 64K 60 Hz
    Supported Mode 121 1360x1024 (16 bits) 64K 60 Hz
    Supported Mode 122 1360x1024 (16 bits) 64K 60 Hz
    Supported Mode 123 1360x1024 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 124 1360x1024 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 125 1360x1024 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 126 1366x 768 (8 bits) 256 60 Hz
    Supported Mode 127 1366x 768 (8 bits) 256 60 Hz
    Supported Mode 128 1366x 768 (8 bits) 256 60 Hz
    Supported Mode 129 1366x 768 (16 bits) 64K 60 Hz
    Supported Mode 130 1366x 768 (16 bits) 64K 60 Hz
    Supported Mode 131 1366x 768 (16 bits) 64K 60 Hz
    Supported Mode 132 1366x 768 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 133 1366x 768 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 134 1366x 768 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 135 1400x1050 (8 bits) 256 60 Hz
    Supported Mode 136 1400x1050 (8 bits) 256 60 Hz
    Supported Mode 137 1400x1050 (8 bits) 256 60 Hz
    Supported Mode 138 1400x1050 (16 bits) 64K 60 Hz
    Supported Mode 139 1400x1050 (16 bits) 64K 60 Hz
    Supported Mode 140 1400x1050 (16 bits) 64K 60 Hz
    Supported Mode 141 1400x1050 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 142 1400x1050 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 143 1400x1050 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 144 1440x 900 (8 bits) 256 60 Hz
    Supported Mode 145 1440x 900 (16 bits) 64K 60 Hz
    Supported Mode 146 1440x 900 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 147 1600x 900 (8 bits) 256 60 Hz
    Supported Mode 148 1600x 900 (8 bits) 256 60 Hz
    Supported Mode 149 1600x 900 (8 bits) 256 60 Hz
    Supported Mode 150 1600x 900 (16 bits) 64K 60 Hz
    Supported Mode 151 1600x 900 (16 bits) 64K 60 Hz
    Supported Mode 152 1600x 900 (16 bits) 64K 60 Hz
    Supported Mode 153 1600x 900 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 154 1600x 900 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 155 1600x 900 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 156 1680x1050 (8 bits) 256 60 Hz
    Supported Mode 157 1680x1050 (16 bits) 64K 60 Hz
    Supported Mode 158 1680x1050 (32 bits) 4096M (True Color) 60 Hz
    Monitor \\.\DISPLAY1\Monitor0
    Name Generic PnP Monitor
    ID MONITOR\GSM56B1\{4d36e96e-e325-11ce-bfc1-08002be10318}\0007
    Key \Registry\Machine\System\CurrentControlSet\Control\Class\{4d36e96e-e325-11ce-bfc1-08002be10318}\0007
    Display Device \\.\DISPLAY2
    Device Key \Registry\Machine\System\CurrentControlSet\Control\Video\{232FBBDC-F0A2-45FE-9BBA-BC413A8C22C0}\0001
    Video Modes
    Supported Mode 2 640x 480 (8 bits) 256 73 Hz
    Supported Mode 3 640x 480 (8 bits) 256 75 Hz
    Supported Mode 4 640x 480 (16 bits) 64K 59 Hz
    Supported Mode 5 640x 480 (16 bits) 64K 60 Hz
    Supported Mode 6 640x 480 (16 bits) 64K 73 Hz
    Supported Mode 7 640x 480 (16 bits) 64K 75 Hz
    Supported Mode 8 640x 480 (32 bits) 4096M (True Color) 59 Hz
    Supported Mode 9 640x 480 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 10 640x 480 (32 bits) 4096M (True Color) 73 Hz
    Supported Mode 11 640x 480 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 12 720x 480 (8 bits) 256 60 Hz
    Supported Mode 13 720x 480 (8 bits) 256 75 Hz
    Supported Mode 15 720x 480 (16 bits) 64K 75 Hz
    Supported Mode 17 720x 480 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 19 720x 576 (8 bits) 256 75 Hz
    Supported Mode 20 720x 576 (16 bits) 64K 60 Hz
    Supported Mode 21 720x 576 (16 bits) 64K 75 Hz
    Supported Mode 22 720x 576 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 23 720x 576 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 24 800x 600 (8 bits) 256 56 Hz
    Supported Mode 25 800x 600 (8 bits) 256 60 Hz
    Supported Mode 26 800x 600 (8 bits) 256 70 Hz
    Supported Mode 27 800x 600 (8 bits) 256 72 Hz
    Supported Mode 28 800x 600 (8 bits) 256 75 Hz
    Supported Mode 29 800x 600 (16 bits) 64K 56 Hz
    Supported Mode 30 800x 600 (16 bits) 64K 60 Hz
    Supported Mode 31 800x 600 (16 bits) 64K 70 Hz
    Supported Mode 32 800x 600 (16 bits) 64K 72 Hz
    Supported Mode 33 800x 600 (16 bits) 64K 75 Hz
    Supported Mode 34 800x 600 (32 bits) 4096M (True Color) 56 Hz
    Supported Mode 35 800x 600 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 36 800x 600 (32 bits) 4096M (True Color) 70 Hz
    Supported Mode 37 800x 600 (32 bits) 4096M (True Color) 72 Hz
    Supported Mode 38 800x 600 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 39 848x 480 (8 bits) 256 60 Hz
    Supported Mode 40 848x 480 (8 bits) 256 75 Hz
    Supported Mode 42 848x 480 (16 bits) 64K 75 Hz
    Supported Mode 44 848x 480 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 46 1024x 768 (8 bits) 256 70 Hz
    Supported Mode 47 1024x 768 (8 bits) 256 72 Hz
    Supported Mode 48 1024x 768 (8 bits) 256 75 Hz
    Supported Mode 49 1024x 768 (16 bits) 64K 60 Hz
    Supported Mode 50 1024x 768 (16 bits) 64K 70 Hz
    Supported Mode 51 1024x 768 (16 bits) 64K 72 Hz
    Supported Mode 52 1024x 768 (16 bits) 64K 75 Hz
    Supported Mode 53 1024x 768 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 54 1024x 768 (32 bits) 4096M (True Color) 70 Hz
    Supported Mode 55 1024x 768 (32 bits) 4096M (True Color) 72 Hz
    Supported Mode 56 1024x 768 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 57 1152x 864 (8 bits) 256 60 Hz
    Supported Mode 58 1152x 864 (8 bits) 256 70 Hz
    Supported Mode 59 1152x 864 (8 bits) 256 75 Hz
    Supported Mode 60 1152x 864 (16 bits) 64K 60 Hz
    Supported Mode 61 1152x 864 (16 bits) 64K 70 Hz
    Supported Mode 62 1152x 864 (16 bits) 64K 75 Hz
    Supported Mode 63 1152x 864 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 64 1152x 864 (32 bits) 4096M (True Color) 70 Hz
    Supported Mode 65 1152x 864 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 66 1280x 720 (8 bits) 256 60 Hz
    Supported Mode 67 1280x 720 (8 bits) 256 75 Hz
    Supported Mode 68 1280x 720 (16 bits) 64K 60 Hz
    Supported Mode 69 1280x 720 (16 bits) 64K 75 Hz
    Supported Mode 70 1280x 720 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 71 1280x 720 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 72 1280x 768 (8 bits) 256 75 Hz
    Supported Mode 73 1280x 768 (16 bits) 64K 75 Hz
    Supported Mode 74 1280x 768 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 75 1280x 800 (8 bits) 256 75 Hz
    Supported Mode 76 1280x 800 (16 bits) 64K 75 Hz
    Supported Mode 77 1280x 800 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 78 1280x 960 (8 bits) 256 60 Hz
    Supported Mode 79 1280x 960 (8 bits) 256 70 Hz
    Supported Mode 80 1280x 960 (8 bits) 256 72 Hz
    Supported Mode 81 1280x 960 (8 bits) 256 75 Hz
    Supported Mode 82 1280x 960 (16 bits) 64K 60 Hz
    Supported Mode 83 1280x 960 (16 bits) 64K 70 Hz
    Supported Mode 84 1280x 960 (16 bits) 64K 72 Hz
    Supported Mode 85 1280x 960 (16 bits) 64K 75 Hz
    Supported Mode 86 1280x 960 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 87 1280x 960 (32 bits) 4096M (True Color) 70 Hz
    Supported Mode 88 1280x 960 (32 bits) 4096M (True Color) 72 Hz
    Supported Mode 89 1280x 960 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 90 1280x1024 (8 bits) 256 60 Hz
    Supported Mode 91 1280x1024 (8 bits) 256 70 Hz
    Supported Mode 92 1280x1024 (8 bits) 256 75 Hz
    Supported Mode 93 1280x1024 (16 bits) 64K 60 Hz
    Supported Mode 94 1280x1024 (16 bits) 64K 70 Hz
    Supported Mode 95 1280x1024 (16 bits) 64K 75 Hz
    Supported Mode 96 1280x1024 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 97 1280x1024 (32 bits) 4096M (True Color) 70 Hz
    Supported Mode 98 1280x1024 (32 bits) 4096M (True Color) 75 Hz
    Supported Mode 99 1360x 768 (8 bits) 256 60 Hz
    Supported Mode 100 1360x 768 (16 bits) 64K 60 Hz
    Supported Mode 101 1360x 768 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 102 1360x1024 (8 bits) 256 60 Hz
    Supported Mode 103 1360x1024 (16 bits) 64K 60 Hz
    Supported Mode 104 1360x1024 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 105 1600x 900 (8 bits) 256 60 Hz
    Supported Mode 106 1600x 900 (16 bits) 64K 60 Hz
    Supported Mode 107 1600x 900 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 108 1600x1200 (8 bits) 256 60 Hz
    Supported Mode 109 1600x1200 (16 bits) 64K 60 Hz
    Supported Mode 110 1600x1200 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 111 1680x1050 (8 bits) 256 59 Hz
    Supported Mode 112 1680x1050 (8 bits) 256 60 Hz
    Supported Mode 113 1680x1050 (16 bits) 64K 59 Hz
    Supported Mode 114 1680x1050 (16 bits) 64K 60 Hz
    Supported Mode 115 1680x1050 (32 bits) 4096M (True Color) 59 Hz
    Supported Mode 116 1680x1050 (32 bits) 4096M (True Color) 60 Hz
    Supported Mode 117 1920x1080 (8 bits) 256 59 Hz
    Supported Mode 118 1920x1080 (8 bits) 256 60 Hz
    Supported Mode 119 1920x1080 (16 bits) 64K 59 Hz
    Supported Mode 120 1920x1080 (16 bits) 64K 60 Hz
    Supported Mode 121 1920x1080 (32 bits) 4096M (True Color) 59 Hz
    Supported Mode 122 1920x1080 (32 bits) 4096M (True Color) 60 Hz
    Monitor \\.\DISPLAY2\Monitor0
    ID MONITOR\GSM5774\{4d36e96e-e325-11ce-bfc1-08002be10318}\0008
    Key \Registry\Machine\System\CurrentControlSet\Control\Class\{4d36e96e-e325-11ce-bfc1-08002be10318}\0008
    Display Device \\.\DISPLAYV1
    Device Name RDPDD Chained DD
    Device Key \Registry\Machine\System\CurrentControlSet\Control\Video\{DEB039CC-B704-4F53-B43E-9DD4432FA2E9}\0000
    Device Flags DISPLAY_DEVICE_MIRRORING_DRIVER
    Display Device \\.\DISPLAYV2
    Device Name RDP Encoder Mirror Driver
    Device Key \Registry\Machine\System\CurrentControlSet\Control\Video\{42cf9257-1d96-4c9d-87f3-0d8e74595f78}\0000
    Display Device \\.\DISPLAYV3
    Device Name RDP Reflector Display Driver
    Device Key \Registry\Machine\System\CurrentControlSet\Control\Video\{b043b95c-5670-4f10-b934-8ed0c8eb59a8}\0000
  19. I might have missed it but what version of windows are you running?
  20. I am running windows 7 64 bit.
  21. well I finally got the crashes to occur running safe mode and also Ubuntu live off USB as well, so I guess that rules out windows.
    The syptoms really seem to point at memory issues, so I decided to remove some of my RAM despite the fact that memtest says it is all fine.
    since doing so I have had no further crashes, so fingers crossed that is the cause of my problems.
  22. Good to hear hope it stays that way
Homebuilt Systems
