Program like gpu-z to monitor temps for my cpu
Last response: in CPUs
Related ressources
- [Other Software] using Hardware monitor and gpuz to see temperatures - Forum
- Why is gpu-z the only program that can read my gpu temp ? - Forum
- XFX 6770 Temperatures at 88'C at GPU-Z and 65'C at CATALYST ! - Forum
- GPU-Z showing two GPU Temp readings - Forum
- What program to check temps ? - Forum
Related ressources:
- ForumGPU-Z or GPU dying?
- ForumGpu-z issue with xfx 4850
- ForumGPU-Z ?!
- ForumHow do you know the temp of your CPU , RAM? Software for reading temps
- ForumHW Monitor , GPU-Z and CCC can't all be wrong, can they?
- ForumPhysx wont show on gpu-z
- ForumFx-8120 fan speed and temps jump up and down like a yo-yo
- ForumTemp monitoring program ? gtx670
- ForumMy high end PC lags like hell!
- ForumAre the temps OK?
- ForumAMD ii x2 550 unlock Which program gives you cpu temps after unlock?
- ForumAre my 6950 CF temps normal?
- ForumWhat do you guys use to monitor your temps , usage etc in game?
- Forum212 evo fan replacement
- Forum[Solved] MX4 and chipped CPU - Fluctuating CPU temps?
- More resources
