Having second thoughts on PSU wattage - will it power this build?
Hi guys, I'm wondering whether an OCZ Fatality 550W PSU will be enough to power this build, any input would be greatly appreciated!!
MOBO: Gigabyte GA-Z68X-UD3H-B3
http://www.gigabyte.com/products/product-page.aspx?pid=3853#ov
CPU: Intel i5 2500k (oc'ed)
CPU FAN: Coolermaster Hyper 212
GPU: Gigabyte HD Radeon 6850 1GB 256-bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125353
HDD: Samsung Spinpoint F3 1TB
RAM: Kingston HyperX 2133mhz 2x4GB
And two 120mm case fans.
Here's the PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
2 answers Last reply
More about having thoughts wattage power build
    Here's the PSU:
    I've got the same PSU and it's fine for me. Since it's out of stock at newegg though I'd go with this one:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044
    If you double your GPU's you'll need it.
  2. I would consider going for a good 80+ 620w+ PSU, especially if you're planning on expanding your build. Also remember to leave yourself some headroom in the wattage department.
Homebuilt Build Power Systems Product
