Seeking advice on a build for running CAD (revit
Approximate Purchase Date: Next six months
Budget Range: 2200 dollars
System Usage from Most to Least Important:Most important working with revit architecture, and general home usage.
Parts Not Required: HDDs, mouse, keyboard, display,os
Preferred Website(s) for Parts: Newegg and Amazon
Country: U.S.A
Parts Preferences:Intel build
Overclocking: No
SLI or Crossfire: Probably not
Monitor Resolution: 1920x1200 or higher
Additional Comments: I have been considering a mac (imac or mac pro) but am frustrated by the price for the amount of performance. Never done a build before and want to have an easy time installing. In the interest of comparing to imac I would like to keep the price under 2200 hundred dollars. Thanks for the help and feel free criticize my ideas and offer alternatives.
Here is what I thought might work just looking around on new egg
-Case: Antec Nine Hundred Black Steel ATX Mid Tower Computer Case with Upgraded USB 3.0
-Motherboard: ASUS Sabertooth X58 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
-Cpu: Intel Core i7-3960X Extreme Edition Sandy Bridge-E 3.3GHz (3.9GHz Turbo) LGA 2011 130W Six-Core Desktop Processor BX80619i73960X
-Graphics card: ASUS ENGTX560 DCII OC/2DI/1GD5 GeForce GTX 560 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
-Dvd drive: LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 - OEM
-Memory: Either 16 or 24 gb G-Skill
-ssd: Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD)
-Psu: OCZ ModXStream Pro 600W Modular High Performance Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom
-Cpu fan: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
Thanks for the help
4 answers Last reply
More about seeking advice build running revit
  1. The mobo what you choosed is X58 socket 1366 , you need X79 socket 2011.
    3960X is a waste of money. Buy 3930K also six core.
    The CPU cooler what you choosed is not compatible with 2011 socket you need this Coolermaster : COOLER MASTER Hyper 212 EVO
    MOTHERBOARD : ASUS Sabertooth X79 LGA 2011 Intel X79
    If you don't want that Asus X79 Sabertooth than choose one from this list
    VIDEO CARD : MSI N560GTX-Ti Twin Frozr II 2GD5/OC GeForce GTX 560 Ti (Fermi) 2GB 256-bit
    PSU : SeaSonic M12II 620 Bronze 620W 80 PLUS BRONZE Certified Modular Active PFC
    CPU : i7-3930K
    SSD : Mushkin Enhanced Chronos 2.5" 120GB SATA III
  2. For your work you need IPS pannel monitor.
    This is verry good : Dell UltraSharp U2312HM Black 23" 8ms Widescreen LCD IPS Panel Monitor with LED
  3. SSD: Crucial M4 128GB
    Mobo: MSi X79A-GD65 8D or with some nice x79 asus mobo
    note what sosofm said make sure if your buying the cm hyper 212 cpu cooler is that it should have the EVO
    don't waste money on a x58 system, the x79 system is the way to go
  4. Thanks for the help guys.
New Build Systems Product
