Approximate Purchase Date: This week or next.
Budget Range:$1,000 before rebates etc.
System Usage from Most to Least Important: Gaming first and foremost, some backing up of DVD's not a lot.
Parts Not Required: I have a G510 Keyboard, Razer Naga, Good Monitor and a XFX 6850
Preferred Website(s) for Parts:Newegg
Country: U.S.A.
Parts Preferences:Intel full tower.
Overclocking: Yes
SLI or Crossfire: Yes in the future.
Monitor Resolution: 1920x1080
Additional Comments: Dont need a lot of Bling or lights flashing all over the place, just a solid gaming PC to last for a couple years. If the price can get below 1k even better, Like I said this is my first time for this so any advice/critisicm appreciated.
COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full Tower Computer Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
ASUS P8Z68-V PRO/GEN3 LGA 1155 Intel Z68:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131790
CORSAIR Professional Series Gold AX850:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139015
Intel Core i5-2500K Sandy Bridge 3.3GHz:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231440
Western Digital RE4 WD5003ABYX 500GB 7200 RPM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136697
Microsoft Windows 7 Home Premium SP1 64-bit - OEM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Country: U.S.A.
Overclocking: Yes
