Hi all,
I am about to build a server using the new Cooler Master Cosmos II Ultra Tower case as the enclosure. I am going to be replacing and adding a number of fans but don't seem to be able to find size specs for the compartments. If you have a look at a video of the case, you'll see that it has a compartment above the "roof" that will accept 3 x 120 mm fans. I'd like to install 3 x Scythe Ultra Kaze fans there. They measure 120 x 120 x 38 mm.
I'd also like to install four fans in the bottom compartment where the power supply lives along with a possible 6 hard drives. I would like to know if I can install the same type of fans in there as well? Two on each side and still have enough room for the drive cages? I believe there is a possibility of mounting yet another fan in the front panel that leads into the hard drive area. Might I be able to mount yet another fan there?
Hope some one can run a tape measure over these areas and let me know, I'd really appreciate the help.
Regards,
John.
Regards,
John.
