Greetings All:
I posted a while ago, I'll summarize the problem though - My girlfriend's computer was bought on Black Friday I believe 2 or 3 years ago, and it was a premade HP. Recently, I upgraded the video card from a Nvidia GT 220 to a Nvidia GTX 550 ti so she could play Star Wars: The Old Republic better, but the lag barely improved in most areas.
The model of the PC is the "a6614f" However, I changed the PSU to the 450W power supply, and the video card is now the GTX 550 ti instead of the GT 220
Specs are as specified -
Power Supply - 450W
Video Card - Nvidia GTX 550 ti
Processor - AMD Phenom(tm) 9500 Quad-Core Processor @ 2.20 GHz
Memory - 6.00 GB
Operating System - Windows Vista 64 Bit SP1
DxDiag - DirectX Version 10
Monitor/Resolution - 21 Inch 1680x1050 @ 60 hz (native resolution)
The Problem -
After installing the GTX 550 ti, I run EVGA Precision and it appears that the GPU usage only tops out at ~25%, no matter what the settings. I thought the reason might be that the video card isn't getting enough wattage to be able to utilize it's full potential so I installed my own 850W power supply, but to no avail, same GPU usage. The game is VERY choppy and the Frames Per Second drop to about 2-4 in any city. My second guess was maybe the motherboard or CPU isn't able to catch up with the video card? I don't even know.
I can answer any additional information requests to what the problem might be, I'm trying to narrow down the causes so I know what I can do to fix it. Thank you very much for any help!
Power Supply - 450W
Memory - 6.00 GB
The Problem -
