L lemeck Distinguished Mar 3, 2012 64 2 18,635 Mar 30, 2012 #1 iMaster PRO 80+ 600w is this power supply alright i have a processor core i5 2600k video card sparkle gtx 560ti MOBO gigabyte z68ap-d3 z68 if it is not can anyone recommend me a low priced power supply haha low budget
Solution lakshitharxx Mar 30, 2012 for a 100$ budget http://www.newegg.com/Product/Product.aspx?Item=N82E16817139023 If you can spend few more $ go for TX 750 and it will allow you to sli later.. http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021 Don't hesitate to spend few for $ for a PSU
geekapproved Splendid Dec 10, 2010 8,766 0 31,460 Mar 30, 2012 #2 No it's junk. First we need to know what country your in, then we need to know your budget. Upvote 0 Downvote
L lemeck Distinguished Mar 3, 2012 64 2 18,635 Mar 30, 2012 #3 philippines if i convert it to dollar hmm 100$ dollar is my maximum for the power supply Upvote 0 Downvote
L lemeck Distinguished Mar 3, 2012 64 2 18,635 Mar 30, 2012 #4 is this power supply good Thermaltake Smart 530w 80+, or Thermaltake Smart 630w 80+? Upvote 0 Downvote
lakshitharxx Distinguished Jan 26, 2011 389 0 18,810 Mar 30, 2012 Solution #5 for a 100$ budget http://www.newegg.com/Product/Product.aspx?Item=N82E16817139023 If you can spend few more $ go for TX 750 and it will allow you to sli later.. http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021 Don't hesitate to spend few for $ for a PSU Upvote 0 Downvote Solution
L lemeck Distinguished Mar 3, 2012 64 2 18,635 Mar 30, 2012 #6 Best answer selected by lemeck. Upvote 0 Downvote
Proximon Illustrious Apr 10, 2006 14,620 3 41,465 Mar 30, 2012 #7 This is always a problem. You just don't have a lot of options there. Here is the biggest list of PSUs I have seen: http://www.pcbodega.com/pcb2/pricelist.php The Silverstone Strider Plus on that page is a good PSU. The 500W would be enough for you, and I think it fals into your budget range. Upvote 0 Downvote
geekapproved Splendid Dec 10, 2010 8,766 0 31,460 Mar 30, 2012 #8 Dang Lak, didn't know Newegg was now shipping to the Phillippines. Upvote 0 Downvote
