I think this may be a driver issue, so I figure this is the right place to ask.
I am using a sennheiser PC 150 headset and running nforce audio drivers. I run Skype, which is the only program i use which involves the headset.
My volume keeps autoadjusting to low whenver i move it or speak. Literally i will be on the volume screen, move it up, and it will immediatly jump back to next to nothing. I have disabled autoadjust from Skpe, so I think there must be some other problem. I have tried everything I know how to make the volume stay where it should, but to no avail.
If you have any possible solution, please let me know. I am willing to try new drivers, change codecs, or do whatever to get it to work. Thanks
-MKLance
-MKLance
