Simple Question on Power Connections
  • Power Supplies
  • Power
  • Fan Controller
  • Components
Last response: in Components
July 13, 2012 1:47:10 PM
If I were to use molex cable extensions, Is the current affect at all? I have a fan controller that needs to supply a certain amount of watts to each channel and I need to use this:
I would leve the 3 pin alone and just use the molex. this a bad idea?
More about : simple question power connections
July 13, 2012 6:51:46 PM
It should be fine
m
l
July 14, 2012 3:23:42 AM
Should work just fine, Wouldn't effect the power at all. I think you would need a crazy long extension to even effect the power draw from the power source.
m
l
