Whats wrong with my nvidia grafics card my monitor keeps turning off
Graphics card Master
Monitor Expert
Please use EDIT to remove your e-mail. Spam bots will send you even more spam then you may be getting now.
Does this happen as soon as you watch a movie? or is it just going to sleep while you leave the system idle?
Hi, Im not 100% sure it's a monitor problem:
1- check in your monitor menu if it's set to auto detect settings, got that kind of problem from an IINC monitor.
2- does your video card have 2 port, you can try the other one
3-check for virus/spyware with malwarebytes
How do you know it's a monitor issue: can you turn it back on or you have to power on you computer once you tried to start skype ? Did you test an other monitor ?
Related ressources
Monitor Expert
Check your power save settings. If they are set wrong, the screen will go off to save power(Idle power down).
Most video players should stop this, but it is something to look into.
Ask the community
