Display Port to HDMI Adapter Help!
  • Graphics Cards
  • HDMI
  • Dell
  • Graphics
  • Displays
January 23, 2012 11:13:47 PM
Ok I have a Dell S2409W (DVI), A Dell 19014FP (DVI), and a Samsung HD 3D TV (DP To HDMI Adapter).
I was wondering if I could extend my desktop onto the Samsung. I can do it if I unplug one of the other two but if I have all 3 plugged in and try to extend the display it says: "Unable to save display settings"
I used to have it so it was just a straight HDMI to the TV and that didn't work so I tryed the Adapter and it still isn't working.
This is my current Adapter:
I was wondering if this one would work:
I'm guessing since the first one is passive and dosen't convert the single that it still thinks its a HDMI so the other one is Active which should switch it to a DP single.
Thanks Please Help
More about : display port hdmi adapter
January 24, 2012 6:45:26 PM
Quote:
1. You'll need an Active display port adapter for eyefinity on your 5870,
2. Links not working
3.Update Drivers?
Yeah I don't know why the links didn't work and my drivers are all updated.
The second link above it said it was a active adapter
m
l
