I am having lots of problems trying to get my new floppy drive to work. Before I start its a "COMP USA" drive that I got at...ya you guessed it. Anyway I hooked it up physically and everything is fine. The lights come up right "not constant which I know means the IDE cable is in wrong" and bios and windows see it fine. But it wont read a disk. It usually just hangs in windows when I try to access the drive. Also I put back in my old floppy drive for few days and that worked fine but then suddenly windows would not see it right. It labeled it as a removable disk for some reason. So that begs the question is my new floppy drive defective or is it something else. Am thinking I have a bad floppy IDE cable perhaps? Its an old one I have been using for 3-4 years. Am not sure how likely something like that can go bad......if at all.
On a side note another problem I have been having.......which could be the problem to the floppy drive. Is that sometimes after turning the power off and playing with the powercords in the case my monitor has problems kicking in. Anotherwords the light would stay orange and not come green. To me that sounds like a power supply problem.
I have a 300 watt supply and the following system specs. Could you tell me whether or not 300 watts is enough for what I have?
Athlon T-bird 1000
A7V Motherboard
Geforce 1
SBL
2 NIC cards
1 IBM 60gb HDD
1 Maxtor 30gb HDD
2 cdroms
5 fans in my case
plus the floppy of course.
Is 300 enough for all that? Also could the power be the reason my floppy is not working right? Any feedback would be great. Thanks in advance
Athlon T-bird 1000
A7V Motherboard
Geforce 1
SBL
2 NIC cards
1 IBM 60gb HDD
1 Maxtor 30gb HDD
2 cdroms
5 fans in my case
