Closed
Help setting up my Graphic Card
January 24, 2012 5:53:18 PM
Hello yall I just built me a New Gaming Computer on Sat & im having trouble with some things here is the spec of my PC
Gigabyte 970A-UD3 Socket AM3+ 970 atx amd motherboard
Amd Phenom II X4 840 Quad-core Processor 3.2Ghz Overclock it to 3.8ghz
Corsair
Hydro Series H70 High Performance Water CPU Cooler
Patriot G Series Sector 5 4Gb DDR3-1600mhz
Timing 8-9-8-24
EVGA Nvidia GeForce GTX 560 Superclocked 1GB GDDR5 Graphic Card
Hitachi 500Gb 7200rpm 16MB Cache Sata 3.0Gb/s 3.5 Internal
hard drive
Ocz ModXStream Pro 700Watt ATX Power Supply
Antec Gaming Case W/ Blue Neon Lights
LG 22x Dvd Burner+Dual Layer
I got everything set up & im looking at the amd overdrive & I look into the GPu Status & my graphic card is not operating on amd overdrive? I open up a different program & my graphic card is showing it working & the clock setting is at 0mhz & Shader Clock 0mhz I need help setting it up & try to go into bios to find the setting of it but cant find it no where!! Also on my motherboard my usb keyboard keeps shutting off & on & I go to look on Amd Overdrive the Diagram & my PCIe is not showing also my other usb is not showing on the diagram!! Can someone help me out I would post pic but i dont see how to attach them or even try to show yall what problems im having!!
More about : setting graphic card
a c 160 Î Nvidia
January 24, 2012 10:40:58 PM
Here is our troubleshooting thread to make sure you assembled everything right http://www.tomshardware.com/forum/261145-31-perform-ste...
GPU is nvidia and therefore not compatible with AMD overdrive but you should have a control panel that came with the drivers! Sometimes you have to activate controllers in BIOS like USB3.
Score
January 25, 2012 1:00:32 AM
oh ya ok thank you for letting me know that nvidia wont work for amd overdrive But i went to that link & that not the problem that im having trouble with!! Do you know the Diagram on the Amd overdrive? my Pcie card is not showing there & my other usb plug in... on window 7 gadgets I have a Gpu Meter it showing my Gpu clock is 0mhz
also Shader clock 0mhz also how do I change the setting?
Score
January 25, 2012 1:37:55 AM
Do you have your GPU enabled as the main graphic card in your bios, also try different pcie slots, could be a faulty slot as well.
Score
January 25, 2012 1:42:14 AM
Im pretty sure I do it showing that it is working but the clock setting are at 0mhz even the shader clock 0mhz!! do you know the diagram on amd overdrive it shows the pcie not there & my other usb stuff not showing my keyboard keeys turning off & on idk what to do!! I have it graphic setup on Peg if you know what that is?
Score
a c 160 Î Nvidia
January 25, 2012 1:48:30 AM
clock at 0MHz means not working, no display? Maybe software incompatibility! Maybe no nvidia drivers installed! Try this for monitoring http://www.techpowerup.com/gpuz/
Score
January 25, 2012 1:58:10 AM
Oh ya Damn well I have used that program before it showing the PCi-e is 1.1x16 my graphic card is a 2.0 dont know why its showing 1.1x16??? the GPu clock speed is at 100mhz memory clock 1026 & the Shader clock is 135mhz... Im on a different program called CPU-Z & im on the graphic its shows on default Clocks
Core 50mhz
Shaders 101mhz
Memory 135mhz
Score
January 25, 2012 2:09:42 AM
Is the Graphic Card suppose to Run at what clocks they are when you first start the computer or when you are testing it for benchmark? cause when I test it the clocks speeds jumps where its suppose to be at it shows that it working & the Temp is like 64 does that mean its working? or are you suppose to set up the clock speed of the graphic card the way it suppose to be?
Score
January 25, 2012 5:35:45 AM
Your card is working, those are the idle clocks, they go up, with 2d usage and 3d usage.
When you are under full load, like gaming, your clocks should be:
Core Clock: 850MHz
Shader Clock: 1700MHz
Memory Clock: 2052mhz
For your card at stock settings
And there is also a midle ground(2d) when you are watching vids, surfing the web and what not.
Score
January 25, 2012 5:44:24 AM
ya ok it seems to be working cause i been playing alot of games! On the amd overdrive the diagram you know its showing that the pci-e not showing & my usb ports keep turning off my keyboards & mouse & stuff why is that? do I have to update bios or something update the drivers?
Score
January 25, 2012 5:46:41 AM
I got this gadget for window 7 its a Gpu meter its showing that my Gpu clock is 0mhz
Shader Clock 0mhz also I dont know if i have to change the settings in the bios or not? my computer is acting weird here & there someone just told me to update my graphic driver card i Did then i restarted my computer I had my computer overclock at 3.8ghz & when I restarted everything in the bios restarted itself idk whats going on?
Score
January 25, 2012 10:07:40 AM
That's odd, try updating your motherboard's bios, and for monitoring your GPU download MSI afterburner or EVGA precision.
Score
January 25, 2012 10:36:44 AM
Ya so Far updated bios I think I went to my motherboard website downloaded this gigabyte driveragent scan reults came back saying
Display adapters
nvidia geforce Gtx 560 old
IDe ata/atapi controllers
standard dual channel pci ide controller old
Disconnected Devices
Generic PnP Monitor Old
Hid- Compliant Mouse Old
Usb Input Device Old
I dont know why all this says old? everything else is check green meaning that the driver or something is good!! what can I do?
Score
a c 160 Î Nvidia
January 25, 2012 8:58:27 PM
Old just means there are new versions of the drivers available from the hardware manufacturer.
You get all the motherboard drivers from gigabyte. Nvidia driver you get from here http://www.nvidia.com/Download/index.aspx?lang=en-us and so on for all your hardware.
Score
January 28, 2012 1:05:58 AM
I solved my Problem & got the best answers!!
Score
Best solution
January 28, 2012 1:09:51 AM
Good to know! now you can enjoy your system.
January 28, 2012 6:28:40 PM
Best answer selected by michael06.
Score
a c 171 Î Nvidia
January 28, 2012 7:41:50 PM
This topic has been closed by Mousemonkey
Score
