Help me with my build
Last response: in Systems
(Sry my language :)  )
Hi, i'm the new guy here and this is my 1st post.
Im going to buy new computer, but i cant decide few parts of it. My budget is about 600$ and i'm going to use this computer mostly for gaming. So this is my build:
MoBo: GIGABYTE GA-890FXA-UD5
CPU: AMD Phenom II X4 965 Black Edition Deneb 3.4GHz
GPU: SAPPHIRE Radeon HD 6870
HDD: Western Digital Caviar Black 500 Gb
Case: Rosewill CHALLENGER-U3
Memory: Haven't decided yet :)
PSU: Same :)
Iwould like to hear some thoughts about this build, some advices. Thank you :)
More about : build
You can do way better than a Phenom II for the price. It's so old and it's far outperformed by any Sandy Bridge build.
Try this:
Case: Cooler Master HAF 912 - $59.99 ($10.00 MIR)
PSU: Corsair CX600 - $69.99 ($20.00 MIR)
Motherboard: Intel BOXDH67DLCB3 - $89.99
CPU: 3.3GHz Intel Core i3-2120 - $189.99
RAM: Mushkin Enhanced Silverline 8GB 1333MHz 1.5V - $42.99
HD: Seagate Barracuda ST 1TB - $89.99
Optical: Lite On DVD Burner - $17.99
Video Card: Sapphire Radeon HD 7770 - $159.99
Total: $652.82 - $30.00 MIR = $622.82
Try this:
Dont know about intel, and i wanned to get one more GPU later for Crossfire, thats why i picked that MB.
Is I3 intel really better than Phenom, i was going to OC it.
Related ressources
Absolutely - any Sandy Bridge CPU is infinitely better than any AMD CPU right now - even the Pentium G620 far outperforms the FX-8150. It's true that the i3s and lower end i5s don't have an unlocked multiplier which means you can't overclock but it will be a far better system in the long run. It's also true that the H67 doesn't have 2 x x16 lanes - if your future plans include Crossfire or SLI you could pay about $40 more and get this motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Have to think about it, i was kinda sure about amd based computer, you made me think :)
I just wanted to get quad core, because many games uses 3 cores.
I have to read a little more, ty for opinion.
Which one of I5's have unlocked multiplier?
+1 if gaming is your priority go sandybridge intels anyday of the week over anything amd has
Ask the community
