Solved
Computer sees wireless network but it won't connect even wired
I'm desperately trying to set up my old D-Link DI-524 on my parent's Toshiba laptop...I'm visiting and going thru withdrawals! I've installed it, run the wizard etc but it doesn't work...not even wired. I've tried various cable configurations and I get nothing. Both cables are good and work just fine connected to the modem. I've reset it a few times, upgraded the firmware and still nothing...I'd think I'd at least get it to work hard wired. My laptop can see the network I set up even...but no data transmission. I'm not a wireless expert, but I need to become one fast!
Greatly appreciate any and all help
Dave
4 answers Last reply Best Answer
More about computer sees wireless network connect wired
  1. Best answer
    are you connecting to a DSL?
    try setting your router's LAN IP to 192.168.5.1
  2. Best answer selected by ysoytnly.
  3. Emerald, I can't thank you enough...that was all it was. You're the best!!!!
    Dave
Configuration Laptops Wireless Network Wireless Networking
