Fps problem with new build
Running swtor on max at about 60 -100 fps
Current build-
i7-2600k
EVGA 570 SOC
16 GB Corsair Vengence
Asus P67 Delxe
Corsair Proffessional 850w Psu
1 TB WD Black HD
But im tring to play company of heroes on max with directx 10 enabled and im only pullin 15-25 fps
My Asus g74 got 50-70 ? How does that make sense.. A laptop with a slower i7 and a waterdowned 560 beats the other rigg???
More about : fps problem build
Related ressources
the great randini said:
i noticed i had some frame problems when i had the asus "aisuite" running at startup. i would unistall or run msconfig click on the startup tab and uncheck.
as far as the overheating, you need to reseat your cpu i bet.
what makes you think the cpu is overheating and also crysis defaults to high but i thibk it should be ultra with my specs
What resolution are you running at?, the laptop could be a lower resolution than your "rigg" and if thats the case your system could be bottlenecking your resolution as in you could need more vram or another 570
im running in 1080 and the laptop was 1600 x 900 but my specs should equal out though, ive seen other benchmarks for the same game with same specs but they get 60-80 fps
Ask the community
