Hi,
I bought a PCI Express Sound Blaster X-Fi Xtreme Audio for my Tritton AX Pros, as my mainboard does not feature an optical S/PDIF. I connected the Trittons with the optical cable and the usb connector to the PC.
I got the following problem: No matter what I do, I only get stereo input at the tritton decoder box. I used the Dolby Surround test in that you can reach properties of the SPDIF playback device that you can reach with the volume controls in windows 7. That did work, the Trittons reacted accordingly.
Every other source of DS does not work. No movies, no games. Also, the Tritton control on the cable does not seem to work, maybe because my system detects the usb as an audio device, too?
I have the catalyst driver version 12.6 installed and heard it might have something to do with that...
Any help with this would be greatly appreciated.
Thanks!
Thanks!
